Fuel pump rewire won't prime.
Old Jul 7, 2022 | 04:22 AM
Ude Lose's Avatar
I have a complete fuel system in my evo 8, walbro 450 -8an feed with -6an return / 2150 fic injectors with agency power fuel rail and aeromotive fpr and I also have a stm rewire kit. The problem is that when i go to start the car the fuel system won't prime and I have to continuously crank the car to build fuel pressure to get the car to start. Shouldn't the fuel system prime when I turn the key?
I am running a 6262 and tuned by rrt.
Any help would or insight would be appreciated.
Old Jul 7, 2022 | 05:32 AM
Biggiesacks's Avatar
The ecu doesn't activate the pump until it gets a signal from the crank sensor on the engine. So if the lines were filed with air it would take a bit of cranking to purge that all out and get pressure. Should be fine after that. If not you might not be holding pressure on the feed side.
Old Jul 7, 2022 | 07:23 AM
Ude Lose's Avatar
That's strange because my friend has a butcher double pumper on his evo 9 and when he gets in the car and turns the key to accessorie the pump primes. He does not have the fuel pump rewire kit.
Old Jul 7, 2022 | 07:34 AM
Dunno what to say about your buddies car, but that's how the stock ECU works. I'm not sure how you install a double pumper without a wiring job though.
Old Jul 7, 2022 | 07:59 AM
huzzle101's Avatar
Mine also primes when i turn the key to on, I also have a bulletproof double pumper but i am also on a Haltech elite.
Old Jul 7, 2022 | 08:20 AM
There is a tool in evoscan that will let you run the pump with just the ignition and the engine not running. Bottom right under actuators. You can use it to prime/test/purge the fuel system.
Old Jul 7, 2022 | 11:29 AM
Ude Lose's Avatar
if that option is activated will the car prime when turning the key before cranking?
Permanent setting?
I checked all the fuses and relays and everything was good.
Old Jul 7, 2022 | 11:55 AM
Permanent setting?
No, the way it works is you turn the key to on and click activate in evoscan. Then it runs the pump for a few seconds. You gotta repeat it a few times to purge all the air. There's a button for high and low speed fuel pump circuits.
This is really a MUT diagnostic option, and I'm sure there are OBD reader tools out there that could do the same thing.
You should only have to do this once. After the air is out it should crank and start like normal. If not, you have some other issues.
MrEvo9Mong
Jan 11, 2022 06:16 PM
DiztortedGZR
Jun 27, 2014 02:33 PM
Whoop_ass
26
Sep 30, 2009 04:04 AM
bboyrease
Jul 10, 2008 08:21 AM
dustin03
AEM EMS
Apr 8, 2007 07:37 PM
