Coolant leak
Old Feb 23, 2023 | 04:30 PM
varv's Avatar
Coolant leak
Hi guys,
I noticed some coolant under my car and on gearbox case. After brief check I can tell it is definitely not coming from radiator itself but from some kind of sensor pined into thermostat. As you can see in the images below it is green from my Prestone cooland fluid. I think it can be coolant temperature sensor? Is it common for it to leak?
Old Mar 1, 2023 | 03:24 PM
varv's Avatar
Can anyone post a photo of their coolant sensor? I want to see how far this screw should go into thermostat housing. I feel resistance and I don't want to turn it to far. Maybe mine is just not tightened enough and that's why it leaks.
Old Mar 1, 2023 | 04:49 PM
ViciousLSD's Avatar
from google-ing images for "lancer evolution thermostat housing"
https://jdmofmiami.com/product/case-...4g63t-evo-vii/
ziptie some paper towels and check it after a drive
Old Mar 29, 2023 | 06:51 AM
PhylisSegal's Avatar
Have you solved this problem?
Old Mar 29, 2023 | 09:05 AM
240Z TwinTurbo's Avatar
Autozone rents a coolant pressure tester for free. When the car is cool just pressurize the system to 15psi and you will see the leak.
Old Mar 29, 2023 | 02:38 PM
varv's Avatar
Yes, I forgot to post it. The problem wasn't the sensor. Coolant was leaking from the pipe straight above because clamp was loose. Thats why sensor was wet I just tighten it up and this solved the problem.
CaptainSquirts
Nov 27, 2017 05:41 AM
changocox1322
Feb 24, 2016 07:09 PM
maevo8
10
May 9, 2012 01:30 PM
liyellowevo8
May 10, 2010 07:51 PM
Dr..Evo
Sep 22, 2009 03:53 PM
