Maperformance 2.4L LR high comp compression numbers
Old Nov 17, 2023 | 02:19 PM
Simpaii's Avatar
Hello guys,
i have a maperformance 2.4L long rod with high comp pistons (10:1). I just recently did a compression test and wanted to compare my numbers with what others with same engine builds have gotten.
engine mods : MAPERFORMANCE 2.4L Long Rod High Comp
Evo ix stock cams
Ferrea valves
Kelford valve springs & retainers
Stmtuned pte6466 gen2 stock location kit
heres the compression numbers
Old Nov 17, 2023 | 04:11 PM
LetsGetThisDone's Avatar
Not sure why you have stock cams, but compression is low. Our 9:1 2.4LR with R2 cams routinely tests at 150psi-160psi.
Old Nov 17, 2023 | 04:39 PM
Simpaii's Avatar
its because im poor , dont have the funds for r2 cams yet. 😅 i know every gauge reads differently but is your evo an 8 or 9 ? I read the 8’s usually have high compression numbers than 9’s.
Old Nov 17, 2023 | 04:42 PM
It's an 8.
However 120psi is below spec even for a factory Evo9 engine which is 8.8:1 compression.
Old Nov 17, 2023 | 04:45 PM
Simpaii's Avatar
Ahh okay , maybe its just a faulty gauge from autozone. I’ll do another test with a different gauge kit and see if it gives me a better reading.
Old Nov 17, 2023 | 04:46 PM
I would certainly get a quality compression tester kit. The cheap ones are inconsistent and inaccurate.
Old Nov 23, 2023 | 05:50 PM
Meathooker's Avatar
MAP engines have a bad history. I wouldn’t run one if it was free … no joke
TACH_MOTOR_WORK
EvoX 'For Sale' Engine Internals and Drivetrain
36
Mar 9, 2014 02:47 PM
FathouseFab
Aug 12, 2012 06:36 PM
SBR INC
Mar 18, 2010 05:39 PM
SBR INC
Nov 17, 2009 11:24 AM
SBR INC
Evo 'For Sale' Engine Internals and Drivetrain
Oct 29, 2009 03:15 PM
