Possible low compression
Old Dec 24, 2023 | 03:38 PM
kanovic's Avatar
Bought a Evo 8 that has been sitting for a long time. In two years it has been driven once. He told me compression is low but from what I have read a lot of it has to do with the car just not being driven. Car is very sluggish but i suspect it’s also tune related. Last time it got tuned was in 2013 and not sure if it’s still the same tune etc.. we did a compression test today and one cylinder is low but I think I will drive it for 2-3 weeks and retest again and see how it goes. Anyone had anything similar where car sat for so long? Gas is also very old so the sluggishness I am sure is part of that also
Old Dec 26, 2023 | 11:10 AM
LetsGetThisDone's Avatar
#4 isn't doing so hot compared to the others. Would suggest a leak down test, and borescope that cylinder.
Old Dec 26, 2023 | 12:15 PM
kanovic's Avatar
that’s what I plan on doing. Want to drive the car for a few weeks and retest again to see if it was just from sitting so long
Old Dec 26, 2023 | 06:38 PM
schuhie's Avatar
I'd just do the leak down now. It will at least get you pointed in a direction.
While not impossible it improves if driven, it seems pretty unlikely given that the dry and wet compression test were the same. I'd be looking hard at a big scratch in the bore or a leaky valve.
Old Dec 26, 2023 | 08:25 PM
It "could" have a sort of stuck ring that "might" come free with some driving.
Not likely though.
Old Dec 27, 2023 | 10:02 AM
RallySport9's Avatar
Yea I'd be looking for damage over anything. The car sitting too long shouldn't affect the bores or rings and make the engine lose compression. Unless it's sitting for a VERY long time and very bad storage conditions.
Old Dec 28, 2023 | 06:47 AM
schuhie's Avatar
Not likely though.
Yup, that was my thoughts as well. It isn't "impossible" that it would improve but a leak down would at least point in a direction before he just drives it around to see what happens lol.
Old Dec 28, 2023 | 08:19 AM
mitsuatb's Avatar
Low reading when wet (ie teaspoon of oil) means bad valve in #4.
Oil (Wet) will seal the rings but not the valves.
Mitsuatb
Old Dec 28, 2023 | 06:51 PM
kanovic's Avatar
Mitsuatb
that honestly would be better then have ring issues anyway. Will do a leak down test!
Old Dec 29, 2023 | 09:11 AM
Abacus's Avatar
Compression and leak down are a static test. Its possible to have a worn cylinder with those test but still run decently. If its not fouling the plug out or smoking alot I would drive it a few tanks of fuel and recheck the plugs.
Old Jan 2, 2024 | 01:45 PM
kanovic's Avatar
there is absolutely zero smoke. Had a rough idle when you crank it for the first few minutes but it’s been 13years since it been tuned and it’s turned on speed density so I think the tune needs a touch up. But once you drive it a little everything seems completely normal. Slow but it is stock so
sturz0
Jan 1, 2015 12:32 PM
EvoIXPilot
Feb 13, 2013 02:01 PM
MaDD-Myke
Mar 7, 2012 06:52 AM
rgar
Feb 16, 2009 06:51 PM
1.8t
13
May 17, 2005 03:42 PM
