Max Boost!!
Old Apr 29, 2004 | 03:15 PM
moviemadness's Avatar
Max Boost!!
Wsup guys.
As you all know the stock boost on the evo is around 19 psi.
What is that maximum boost and hp the engine can handle with stock internals?
A 320 hp cast iron supra engine can handle like up to 600 hp on stock internals.
What do you guys recommend?
Would it be better to just get a larger turbo and lower the boost?
Old Apr 29, 2004 | 03:25 PM
Mitchubishievo's Avatar
I heard around 400 whp is peretty safe for the evo, don't run more than 23 psi of boost on the stock turbo though.
Old Apr 29, 2004 | 05:25 PM
if you get a bigger turbo, then you can lower the psi and still get more hp right?
Old Apr 29, 2004 | 06:49 PM
babyburner's Avatar
no. psi is psi. volumetric movement is another thing. if u get a bigger turbo u can run high psi at a lower spin for ur turbo, which means more efficent. THat does not mean more psi. U will get more lag thou, so unless u up ur redline, it doesn't help that much at 20ish psi
Old Apr 29, 2004 | 07:06 PM
favre95's Avatar
Dude what are you talking about in that jibberish!? Yes, a bigger turbo can run at a much lower "PSI" and still help produce the same amount of horsepower. If it didn't what would be the point of upgrading? The difference is in CFMs. A smaller turbo will not flow as much at a certain PSI. A bigger turbo will flow more CFMs at a lower PSI rating. A bigger turbo will most likely lag more but that is one of the downfalls of a bigger turbo. Do to the natural size and weight of turbos wheel. And the Evo's internals are good for a good amount of HP. DSMers have been producing 400-500 HP on stock internals with their cars for years. No reason why we can't.
Old Apr 29, 2004 | 07:26 PM
so....
a bigger turbo with the same psi would have more hp? but with a significan amount of lag right?
lilenday
11
Jul 12, 2012 12:30 PM
turboturd
Lancer Aftermarket Forced Induction Tech
12
Feb 28, 2006 06:04 PM
Megadeth2118
17
Oct 7, 2004 03:07 PM
yamaneko
Mar 17, 2002 10:31 AM
Lancer Engine Tech
10
Mar 12, 2002 02:48 AM
