Pennzoil Syncromesh
Old May 18, 2004 | 06:51 AM
masterevo's Avatar
Pennzoil Syncromesh
Hey guys, look at what I found out about pennzoil sycnromesh. So basically, it's the same exact stuff as the GM syncromesh. And in the article, it even mention of mitsu AWD tranny. Anybody here use this product before on the EVO?
Old May 18, 2004 | 06:53 AM
matt55's Avatar
Yes and its the best Ive tryed so far !
Old May 18, 2004 | 07:07 AM
masterevo's Avatar
Matt55,
What have you tried in the past? Im going for pennzoil too.
By the way here is the link to the article: http://www.stealth316.com/2-pennzoil-synchromesh.htm
Old May 18, 2004 | 07:12 AM
matt55's Avatar
stock, mobli 1 ,red line mt90 , now pennzoil . I was try to help my 1-2 ,3-4 upshift none realy helped that much BUT pennzoil feels sooooooooo much better when driving like I have some cents . Also tryed short shifter, clutch restrictor removed , stil have quick shiftin prob's ?!
Old May 18, 2004 | 07:19 AM
jj_008's Avatar
It really does work. I am not a big Pennzoil fan and was very hesitant about trying this gear oil, but it really made a big difference in shifting smoothness.
Old May 18, 2004 | 07:46 AM
masterevo's Avatar
I dont really have any shifting problems except grind a little bit on 4th gear while racing. But I noticed that I have to depress the clutch all the way or else it will grind. Im just looking for a good tranny fluids for the EVO tranny. Pennzoil is cheap and can be found at any autozone or local auto shop. BG sycnroshift and GM is expensive and hard to find. I'm going for heavy shock proof redline for x-case and rear diff. Thx guys for the response.
Old May 18, 2004 | 10:23 AM
erioshi's Avatar
I've been using the GM Syncromesh (basically the same as the Pennzoil) and my car has been shifting more smoothly. I only have about 2K on the new fluid, though. Has anyone been driving for an extended period of time on Syncromesh? I also hear the the BG Syncroshift fluid may be even better, but I have yet to try it.
Old May 18, 2004 | 02:32 PM
lilgsx's Avatar
I am using the GM stuff also. I had Royal Purple in it and it SUCKED!!!!! I switched to the GM Syncromesh and it shifts good. I have about 2k on mine also. I will more than like change it out at 5k though just to freshin it up.
Old May 19, 2004 | 07:00 AM
Zeus's Avatar
I've been on the GM for the better part of my 23k... shifts great. I just switched to the Pennzoil and can tell no difference between the two other than price.
Old May 19, 2004 | 01:59 PM
masterevo's Avatar
Yo, update on the pennzoil syncromesh. It works!!!! Almost immediately, after changing out the stock to the pennzoil, the shifting has improved dramatically. Well, maybe I over exaggerate a little bit on that, but nonetheless, there is a huge improvement over the stock fluid. I also use the redline heavy shock proof with 1/2 ouce friction mod for the rear differential. I have not change out the x-case yet. Will do that soon. But so far so good.
Old May 19, 2004 | 02:04 PM
BaLListic_EVO's Avatar
matt ill let you know if a ss clutch line works after that ill be trying some shifter bushings!
KtownEVO8
14
Jul 20, 2009 05:10 PM
EVOKing8
56
Jun 10, 2009 08:18 PM
JT-KGY
Aug 12, 2006 06:03 AM
anjapower
10
Jun 9, 2006 02:38 PM
badhabit90
23
Jan 31, 2006 09:26 PM
