temp changes
Old May 20, 2004 | 07:18 PM
ammitsuevo's Avatar
temp changes
heres a simple question i think- i have a mbc and my boost stayed pegged at 1.4kg/cm2 now since it has been warmer allthe time my boost is now pretty steady at 1.3kg/cm2
is that noramal for the temp to cause this to happen?
Old May 20, 2004 | 07:21 PM
GTVEVO's Avatar
yes this is normal and one of the disadvantages on a MBC. It will changed due to the air being thinner due to warmer weather.
Old May 20, 2004 | 08:20 PM
Bom's Evo's Avatar
yeah i lost 4psi due to the warmer weather. sucks now i gotta set the mbc again. It takes me like 4 tries and the thing gets hot. im gonna mark this one now. cause i have my winter setup marked already.
Old May 20, 2004 | 09:48 PM
1QWKEVO's Avatar
EBC!!!! It has to due with the properties of cold air vs hot air... cold air is denser and you can compress more of it
Old May 21, 2004 | 07:22 AM
Technoz's Avatar
does it work the same for altitude? So If I drive from Chicago to Denver (which I'll be doing this summer) I'll need to crank up the mbc? Although maybe not if they only have 91/92 octane out there
Old May 21, 2004 | 07:37 AM
Fourdoor's Avatar
Yup it works the same for altitude. You will notice a drop in boost with a major altitude change.
Keith
Old May 21, 2004 | 07:42 AM
MalibuJack's Avatar
The only real solution for this is to use a electronic boost controller with closed loop (feedback) boost control.. some of the less expensive EBC's also work similar to an MBC and would require readjustment periodically, obviously doing it inside the car is alot easier. And many have two or more boost settings for that reason.
Old May 22, 2004 | 08:08 AM
ammitsuevo's Avatar
i had an ebc first- the profec b and it was such a pain in the butt. that is why i went to a mbc- so i guess i will have to deal with periodically adjusting it
Old May 22, 2004 | 10:44 AM
1QWKEVO's Avatar
greddy profect b is a poor excuse for a ebc.. lol Try something like a Blitz sbc i-d
Old May 25, 2004 | 06:23 PM
ammitsuevo's Avatar
yeah i agree with you-i am sticking with my mbc for know- i do believe that the profec is a bad ebc for the evo- i am skeptical about all ebc now
thanks for the input
Old May 25, 2004 | 06:29 PM
evo542's Avatar
e-boost is the newest one out there and it comes with flash memory so it could be upgraded whenever new software is available..
EvoDan2004
28
Oct 25, 2013 07:58 PM
Unified-Forums
Evo 'For Sale' Engine Internals and Drivetrain
84
May 13, 2011 09:35 AM
Evoardo IX
11
Mar 19, 2008 06:03 AM
stimpy
12
Aug 23, 2007 10:04 PM
EVO MR FU
44
Nov 27, 2004 12:21 PM
