gas issue!! (HELP)
Old Jul 8, 2004 | 01:49 PM
The Emperor's Avatar
gas issue!! (HELP)
i am tired of using 91 octane here in california. Which is the cheapest way to use 93? Which octane booster? can i run 100 octane!? thanks!
Old Jul 8, 2004 | 01:53 PM
mifesto's Avatar
xylene and mix it with ur gas
Old Jul 8, 2004 | 02:03 PM
where do i get xylene? and how much is it?
Old Jul 8, 2004 | 02:07 PM
umiami80's Avatar
Home Depot, its PAINT THINNER< that simple...
Old Jul 8, 2004 | 02:08 PM
is it safe to use "paint thinner"?
Old Jul 8, 2004 | 02:11 PM
cant i just mix 100 octane with 91? how much of each should i mix with?
Old Jul 8, 2004 | 02:48 PM
1QWKEVO's Avatar
tkae 91 and pour one bottle of .ah man i forgot the name its an orange bottle kinda shapped liek a mini quart of oil it will say boosts up to 20 points.. (2 numbers) i'll try and find the bottle, its about 7 bux
Old Jul 8, 2004 | 02:50 PM
1QWKEVO's Avatar
paint thinner is not safe nor is using pure xylene or toulene... there are lubrican'ts in gas which if isn't equally in the booster you will eat up o-rings and booger stuff up
Old Jul 8, 2004 | 03:00 PM
Guack007's Avatar
8 gallons of 91 and 4 of 100 equals 94 octane and is 100% safe. 100 octane will run you between 4.50 and 5.00 per gal.
Old Jul 8, 2004 | 03:04 PM
naucrx's Avatar
Here's a few solutions to boost your octane. I found the site on Google.
http://www.vtr.org/maintain/gasoline-octane.html
Toluene is the common ingredient in octane boosters, so using pure Toluene mixed with gasoline will have the same ill effects on your motor as an "octane booster". I wouldn't recommend using it all the time. Maybe once or twice for a dyno pull or something should be all right.
Leaded race gas and aviation fuel is very high octane (110-130). Unfortunately, leaded gasoline is corrosive and will damage 02 sensors and will clog catalytic converters. I wouldn't use it on your EVO.
The best thing to do, which sucks, is just deal with the 91 **** gas we've got out west. Unless u want to drop $4 a gallon for 100 octane unleaded race gas at 76.
Old Jul 8, 2004 | 03:55 PM
1QWKEVO's Avatar
heres the octane booster.... mix one bottle to a full tank it will give u roughly 93 octane... i've data logged this booster and it will eliminate almost all the detination issues... http://www.midwayautosupply.com/deta...ption.asp?4614
this will bost octane 20 points or 2 pump numbers
there is also a MAX octane booster that does 7 numbers or 70 points, but too much octane isn't good if you don't need it....
Old Jul 8, 2004 | 04:33 PM
umiami80's Avatar
Will if you use toulene, use some Marvals Mystery Oil to lubricate your fuel, you can Safely Add Toulene just not soo much, I think if you run 10 Gallons then 2-3 Gallons Of Toulene is fine.
Old Jul 8, 2004 | 04:43 PM
Az3ar's Avatar
lol. I have 100 octane gas 2 miles away from my house. I mix 3 to 4 G + 8 G of 91 = 93 to 94 cost = $38 Fu$#$. in VA it used to be $19 for 94 gas. oh 100 here in CA of the pump for 5.19 right next to my house as I said above.
Old Jul 8, 2004 | 04:54 PM
1QWKEVO's Avatar
100 octane is too much money, touline is too expensive as well... last time i checked it was 10-20 bux a gallon it was a while go so i'm not sure what its current value is but then again remember u ahve to add some lubricant to it as well.. so if u ask me the cheapest way to resolve this problem is o either add one bottle of that octane booster or try and ad partial mixtures of the MAX octane booster from Gunk...
Old Jul 8, 2004 | 05:03 PM
chrisw's Avatar
If you look at the cost of doing what you suggest, the 100 octane gas is pretty cheap....
