In need of the torque specs on the main bolts for an EVO 8
Old Jul 11, 2004 | 11:00 AM
TRINIOUTLAW's Avatar
Hi - i'm currently rebuilding an '03 EVO 8 motor and was unable to find a set of ARP main studs in time to finish up the motor. I will reuse the OEM Main bolts and I need the torque specs if anyone has the dealer manual. Thanks for your help. Trini!
Old Jul 11, 2004 | 11:17 AM
96_LXR's Avatar
Hope this helps, this is the info from the factory cd manual I have . . . it doesn't really say what the first number is (nm, etc.) but the numbers in () are in ft/lbs.
Good luck
Crankshaft and cylinder block
Beam bearing cap bolt 25
± 2 (18 ± 1 ft-lb) + 90°
Bell housing cover bolt 9.0
± 1.0 (80 ± 8 in-lb)
Check valve 32
± 2 (24 ± 1 ft-lb)
Flywheel bolt 132
± 5 (98 ± 3 ft-lb)
Oil seal case bolt 11
± 1 (98 ± 8 in-lb)
Rear plate bolt 11
± 1 (98 ± 8 in-lb)
Old Jul 11, 2004 | 12:39 PM
Thanks 96_LXR for the info, unfortunately it does not list the Main bolt tq spec. If anyone esle has the info please post it. Thanks again 96!
Old Jul 11, 2004 | 01:06 PM
DocMortal's Avatar
Cylinder Head bolt-
78+-2(58+-1 ft-lb)--back off--20+-2(15+-1 ft-lb)---90 degrees + 90 degrees
dont know the key to make +- in one shot...its in the cd manual
Old Jul 11, 2004 | 01:41 PM
I not sure if i'm listing it right, the Main bolts are the ones on the Main Crankshaft Cap. It locks down the crankshaft from the bottom, if the oil pan was removed you will see them.
Old Jul 11, 2004 | 02:28 PM
DocMortal's Avatar
8 4 1 5 9
7 3 2 6 10
thats the sequence
10 bolts holding the crankshaft to block
25+-2 N:m (18-+1ft-lb)
I think those are what your talking about...
Old Jul 11, 2004 | 02:53 PM
Originally Posted by DocMortal
8 4 1 5 9
7 3 2 6 10
thats the sequence
Yes!! Thanks to all of you all for your help. Trini! We are shooting for 700whp on the dyno with this little 2.0 monster!!
Old Jul 12, 2004 | 12:36 AM
erioshi's Avatar
According to the manual, after tightening to 18 ft/lbs you are supposed to mark the bolts and tighten them another 90 degrees.
Old Jul 12, 2004 | 06:15 AM
darkhorse's Avatar
Shooting for 700 hp? Not with the main caps tightened to 18 ft/lbs. you aren't. But if you do, just watch your feet. You torque the OEM bolts to 18 lb/ft and then go 90 degrees torque angle from there. On the other hand, if I were building a motor that I expected that kind of power from, I would be runnin a better fastener than the stock bolt. I would get the ARPs, I think in the long run you will find that they are worth the wait.
Old Jul 12, 2004 | 07:08 AM
Well...I wanted to get the ARP, but I was told that they don't make an application for the Mains....now that's what my vendor said. I think I will just call ARP myself. BTW, I was planning on locking up the motor yesterday, but due to the OEM main tq spec info issue, I decided to wait and head down to my local Mitsu dealer today and pick up the service manual. Again...thanks!
Old Jul 12, 2004 | 08:11 AM
darkhorse's Avatar
ARP does make a kit for the mains, as well as the heads for the 4G63. Its worth the investment. Get a set, run a tap down the holes to clean up the threads and install them properly. If you are going to be pushing some real loads on the motor, you want at least a good fastener to hold the girdle assembly on.
Old Jul 12, 2004 | 08:23 AM
I just got off the phone with ARP - they said that the EVO 8 uses the same Main studs as the Eclipse 4G63T (90-99) ARP part #207-5401 and needs to be torque to 60 ft lbs with ARP moly. I have those in stock so everything worked out jus fine. I'm quite surprised that my vendor said that there was no ARP application for the EVO 8 Main bolts. Anyways, I always use ARP hardware on my engine rebuilds and the Rods that were using came with ARP hardware. Thanks again!
Tobra
Lancer Tranny/Drivetrain Tech
Jun 3, 2017 08:17 PM
black_beauty
Aug 8, 2016 07:36 PM
bryonboals
Oct 14, 2012 02:03 PM
RogueSTi
Oct 31, 2005 03:51 PM
EvoTio
Nov 6, 2004 09:01 PM
