installed JIC exhaust manifold & Helix o2 housing
Old Jul 29, 2004 | 02:33 PM
  #31
bishiboy's Avatar
The wrap will also decrease time to full boost...
How will wrapping decrease time to full boost.
Anybody that knows about turbos knows that the more exhaust heat energy you keep in the exhaust will increase spool-up.
But, I would think he did it as insulation to keep from cooking the radiator hose and lowering under-hood temps.
(I just corrected a type-o on dis so I'm also knot slammed by da inglish notcees)
Old Jul 29, 2004 | 02:38 PM
  #32
Rez90's Avatar
Originally Posted by alex_alex
1) I call BS on the 1000rpm increase in spoolup
2) This guy can't speak proper English, "recommand this mods" ?
3) Theres no reason why changing the exhaust manifold and the 02 housing would allow the car to pull hard to redline without changing the boost control.
I would probably agree with on # 1 and #3 of your post...but in regards to part 2 of your comment...you're kind of a dick aren't you
Old Jul 29, 2004 | 02:46 PM
  #33
rpm-evo's Avatar
Thanks for the info on the thermal wrapping. It was what I had figured, I just was not sure if it was actually practial or just theory. Guess I'll just monitor the under hood temps for a while.
Old Jul 29, 2004 | 05:41 PM
  #34
alex_alex's Avatar
Oh a total dick. But what can i say, its that time of the month, and people that can't spell **** me off.
Anyhow. . . .on with the topic
Old Jul 29, 2004 | 06:49 PM
  #35
Fenris Ulf's Avatar
LOL, you crack me up man. You answered your own question and are still confused. If you use wrap as an insulator, it is keeping the heat from escaping to the engine bay, meaning it stays in the pipes and provides more thermal energy to spool up the turbo. But then again you already knew that since you know about turbos
Old Jul 29, 2004 | 09:18 PM
  #36
bishiboy's Avatar
You just said the same thing I did. Keeping the heat energy in the pipes transfers to the turbo, thus more heat/exhaust energy going into the turbo.
You said wraping the pipes will decrease the time to full spool, which is the OPOSITE? Ha Ha yourself!
Now, if you are basing this off something your buddy with a turbo Jetta said, I understand.
Old Jul 30, 2004 | 11:51 AM
  #37
Fenris Ulf's Avatar
I said wrapping the pipes will DECREASE time to full boost, meaning the time it takes to get to full boost will be less. This is not the opposite, you are just confused.
Welcome2GoodBur
Apr 3, 2017 07:48 AM
mdknutsen
Aug 27, 2012 08:48 PM
lancer2show
Lancer Aftermarket Forced Induction Tech
13
Mar 29, 2007 11:33 AM
use2vtec
26
Mar 21, 2006 09:57 PM
stvbreal
May 2, 2003 11:54 AM
