Why is my car so slow?
Old Aug 17, 2004 | 05:09 PM
  #31
erioshi's Avatar
OK, so has the "Tuning is everything" horse been beat to death yet? If not let me give it another whack!
Getting the right tune is the single most important aspect of engine set-up. If your car isn't tuned correctly the parts can't work to their maximum ability. A trip to a dyno with a good tuner could easily be the best hp vs $$$ upgrade you can make right now.
Get the car tuned!
Old Aug 17, 2004 | 05:22 PM
  #32
blackevoVII's Avatar
Originally Posted by Jadiem
i'm running 21 psi... thanx for the info z1!!
when i say 4.75 bar, i mean thats the highest it gets when i'm under full boost/load...
There's no way in hell you're running 4.75 bar. Thats like 80 psi. I could be wrong on the 80...but thats HIGH as hell. also, ive only seen boost gauges go up to 2 bar?
Old Aug 17, 2004 | 06:45 PM
  #33
Dyno4mance's Avatar
4.75 bar is 69 psi....You need to get on a dyno with a good tuner after the first pull it will be obvious why your car is not making power
My 2c
Old Aug 17, 2004 | 06:50 PM
  #34
marksae's Avatar
He's referring to fuel pressure. The rate of rise for fuel pressure is 1 psi for every psi of boost. So if fuel pressure is 43 psi at 0 psi, it should be 63 psi when you're at 20 psi of boost.
Old Aug 17, 2004 | 07:46 PM
  #35
Jadiem's Avatar
correct... this is on my Fuel PSI Gauge, i also have EGT and Oil PSI
all in kg/cm2
Old Aug 18, 2004 | 12:39 AM
  #36
marksae's Avatar
Where is your fuel pressure sender located anyway? Is it before or after the FPR?
Anyone know what the idle fuel pressure is with the vacuum hose disconnected off the FPR?
Old Aug 18, 2004 | 03:56 AM
  #37
Jadiem's Avatar
it's before... grab a pic of the Perrin fuel rail, it'll show you where the sending unit goes...
Old Aug 23, 2004 | 02:48 PM
  #38
Jadiem's Avatar
well, got the car tuned with a FJO wideband... night and day differences!!! it still does not feel like a 12 second car due to the humidity, but i think in perfect conditions i can possibly be a 12 second car...
if anyone with the same mods as me with the emanage wants to get a copy of my #s just IM me on AIM..
Old Aug 23, 2004 | 02:50 PM
  #39
2k4EvoVIII's Avatar
You dont have to have it tuned to run 12's. Before i did my major mods i was running 12.4's with 1.7 60 foots with the stock ecu.
Old Aug 23, 2004 | 02:52 PM
  #40
Jadiem's Avatar
but not the stock clutch
Old Aug 23, 2004 | 02:55 PM
  #41
2k4EvoVIII's Avatar
Yup on stock clutch too.
Old Aug 23, 2004 | 03:30 PM
  #42
bolsen's Avatar
Did I mention tuning is everything?
ok ok seriously, glad to hear you are running well!!
9sec9
Apr 16, 2008 04:05 PM
Booztd 3
Aug 14, 2006 09:04 PM
dsmjeffro
Jul 2, 2006 12:47 PM
rt turbo
14
Feb 13, 2005 03:42 PM
JaReDbOy
Sep 23, 2004 10:35 AM
