Stroker Rev Question
Old Sep 5, 2004 | 04:56 PM
  #91
Crazy4Cars's Avatar
Old Sep 5, 2004 | 05:27 PM
  #92
FOURCED's Avatar
Originally Posted by 3240
(Quote=Fourced)
It is impossible for one engine to make twice the torque as another at a given RPM yet both engines make essentially the same HP at that same RPM
Fourced,
I've been thinking about this statement I think that the major flaw in your conclusion is the fact that the AMS engine (2.0l) and my Toda engine (2.3l) can no longer be considered the same engine since mine displaces 15% more than a stock 2.0l.
So, you think there is a major flaw in my conclusion eh?
Let me try to explain it better................... If you had a one cylinder Briggs & Stratton that could make 100 Lb Ft of Torque @ 4000 RPM, .........the HP would be 76.16. (100 x 4000) divided by 5252.
If you had a 12 cylinder, 1200 cubic inch compound supercharged Diesel that made 100 Lb Ft of torque @ 4000 RPM, ........................the HP would be 76.16.
Point being that the slight variation between your engine and the AMS engine means ZERO in terms of how HP or torque are calculated
I looked up the dyno chart of the Toda Evo in SCC and it made a total of 422whp and 390 ft/lbs of torque. That means that peak torque was 92% of the peak HP number. My car's dyno sheet shows 571 peak WHP and 509 ft/lbs of torque. Peak torque in my case is 90% of peak horsepower. These ratio's are remarkably close and they are the only 2.3l dyno charts that I have to compare. Is it possible that my HP to torque number might be more accurate than you originally believed? Just curious.
I realize that dynos can be extremely variable as can 1/4 mile times due to all of the variables involved. Is trap time a good estimate of total horspower? If so take a look at the attached time slip. This is my first run with this car and it was done on 91 octane (472WHP and 418 ft/lbs of torque). My trap time was 114.3 mph, my 1/4 time was horrible due to a poor launch. I've only made one run with this car so this is all that I have. I have an Exedy twin disk clutch which I'm having a tough time mastering at launch. I may upgrade to the carbon twin disk. Please try not to laugh at this slip. At the same time the trap speed seems very impressive for 91 octane at 6000 ft above sea level. Does this trap speed indicate the accuracy of my 91 octane dyno numbers? Thanks for your response.
As a rule, trap MPH is a very accurate indicator of Average Horsepower..........................the problem is that on these small engines with big turbo's and standard transmissions, we tend to spend increasingly more time off boost - as the turbo size increases. During launch and between gears we spend precious seconds @ well below peak power, so the numbers get skewed.
Thats also why a nitrous spoolup shot can be so valuable on a monster turboed / small displacement car.
As for your time slip vs Dyno #s ................571WHP would put a 3400 lb evo through the traps @ 129 MPH and approx. 10.5 seconds depending heavily on the 60 ft. BUT......................If you were spending alot of time off boost between gears or @ launch..............there is no way to predict ANYTHING.
Hope that helps,
JDB
Old Sep 5, 2004 | 05:33 PM
  #93
3240's Avatar
I forgot to mention the weight this car was carrying on this run. I was driving (265 LBS) along with a passenger (205LBS).
On a side note:
I went to the track with the intention of burning through what was left of my tank filled with 91 octane so I could fill up with C16 and run my racing map. I did one run on 91 which is posted. We decided to get something to eat at the track stand and thought it would be a good idea to let the car idle while we ate to burn through some gas (91 octane). I kept the car running, key in the ignition, and took the remote with me so I could lock it. While eating I dropped the remote and wrecked it. So, I spent the rest of the night with a slim jim trying to open the door of my running car. Great first night at the track. Murphy's law at work!
Old Sep 5, 2004 | 05:35 PM
  #94
3240's Avatar
Fourced,
Great info. Thanks.
Old Sep 5, 2004 | 05:50 PM
  #95
FOURCED's Avatar
I retract the above statement about how we can't predict ANYTHING, thats not true........3250 lb car + 265 + 205= 3720LB.
Your avg. (not peak) HP was 465 to the ground. (I use Turbocalc)
Nothing to sneeze At
I thought I was the only one who could pull a stunt like that. (broken remote)
JDB
Old Sep 6, 2004 | 04:23 PM
  #96
3240's Avatar
Not bad for 91 octane. I'm running the C16 map this Wendneday.
Old Sep 8, 2004 | 07:49 PM
  #97
3240's Avatar
Ran the C16 map at Bandimere in Colorado tonight.
Ran 11.533 @ 122.13 mph.
The cars weight was 3530 LBS.
Bandimere is 5800 feet above sea level. Does anyone know the proper conversion factor sor sea level?
R/T .264
60' 1.715
330 4.887
1/8 7.493
MPH 95.7
1000 9.684
1/4 11.553
MPH 122.13
Old Sep 8, 2004 | 11:02 PM
  #98
JustDSM's Avatar
Bandimere is 5814ft
Forced Induction:
.9627 x E.T.
1.0395 x M.P.H.
Old Sep 8, 2004 | 11:04 PM
  #99
3240's Avatar
Ok, if Bandimere is 5800 ft above sea level than the altitude corrected time is 11.122 @ 126.95.
Old Sep 8, 2004 | 11:37 PM
  #100
value's Avatar
Great times 3240 for such altitude. Is it harder to tune way up there
Old Sep 10, 2004 | 07:06 PM
  #101
FOURCED's Avatar
Originally Posted by FOURCED
David, would you please elaborate on your experience with strokers.
I think most people realize that the higher rpm available with the stock stroke will always deliver more Peak Power in an "all out" drag application or Dyno Queen, but............
Since EVO's are relatively heavy, 99% of them are daily drivers, quite a few are road raced/autocrossed and they are all fairly gutless- (off boost and with low boost), I think it should come as no surprise that we NEED more low end grunt.
Edit: forgot to add that synch'ed trannies don't like to shift @ high RPM.
I'm curious to know if you feel that the added friction, subsequent wear and reduced revs of a stroker make it unattractive for ANY application. This is the "vibe" I've gotten from your posts on the subject.
Thanks for any and all input,
JDB
P.S. I've always been impressed with your work and I appreciate your willingness to share your time and knowledge around here!
I guess he didn't wanna talk about it. ??
EvoIX7
13
Jul 27, 2006 06:35 AM
ZyBeR
Dec 14, 2005 10:29 PM
evo8silver
10
May 17, 2005 05:26 PM
Croix
10
Dec 25, 2003 12:01 PM
value
Dec 3, 2003 04:48 PM
