View Poll Results: Do the gears grind in your Evo?
Evo doesn't grind
225
27.54%
Grinds - 1st to 2nd
253
30.97%
Grinds - 2nd to 3rd
189
23.13%
Grinds - 3rd to 4th
110
13.46%
Grinds - 4th to 5th
214
26.19%
Multiple Choice Poll. Voters: 817. You may not vote on this poll
Mitsubishi, synchros and us
Old Sep 21, 2004 | 06:20 PM
  #106
Az3ar's Avatar
Oh, while I was on hold with Mitsu Corp. the message kept saying that the lancer EVO would go from 0 to 60 in 4.49 sec. Holly crap I have not even tried to launch my EVO to reach that I wonder what would have happened to my tranny if I did (my gears will be flying front of me) The thing is why would they sat 4.49 when they know the car will fall apart after that?? They said 4.49 then I should be able to do it right??
Old Sep 21, 2004 | 08:34 PM
  #107
NYREDEVO's Avatar
Cmon guy, they said the lancer evolution would go 0-60 in 4.49....They didn't say it would work after that! lol
Old Sep 21, 2004 | 08:59 PM
  #108
Az3ar's Avatar
Old Sep 22, 2004 | 09:54 AM
  #109
Scooby24's Avatar
Hey just curious have you guys experimented at all with adding Synchromesh to the tranny (not the transfer case)? I don't know a lot about the EVO's yet and don't know if the synchros are having troubles due to defect or possibly too slick of lubricant from the factory.
I have a WRX and switched to synthetic (bad move) and after a thousand miles started to get some pretty bad grinding from 3 to 4. I realized this was the synthetic lube and changed out to 100% GM Synchromesh. I heard lots of worries about this because it's a GL-4 lubricant and Subaru called for GL-5. Well so far I've had it in for about 8k miles and it has been nothing but awesome. The bad grinding I was getting has completely disappeared altogether and I am able to put my car into first (don't do it often) at 20 mph without hesitation. It just slips into place now.
As far as people worried about it breaking down under hard driving: I've auto-xed my car 3 times since putting in the synchromesh and if anything, the hotter the tranny got, the better it went into gear....
Side note: Could someone explain the difference between the transmission and the transfer case? What does the transfer case contain? Center Diff?
Old Sep 22, 2004 | 03:46 PM
  #110
G20's Avatar
G20
Ok! This weekend, I'll change my tranmission oil to Penzoil Synchromesh to see any good thing happen. Will let you guy know.
Old Sep 22, 2004 | 03:48 PM
  #111
Az3ar's Avatar
I am changing mine to Pennzoil, will see.
Mhyar
Old Sep 22, 2004 | 07:13 PM
  #112
mttam510's Avatar
Mhyar
I am not one for the "snake oil", but I swear the stuff works. Again, as I said before synthetic oils are probably too slippery, I used 2 qts, Sycromesh and 1 qt RL 75W90 and it shifts soo much better. I have a bunch of 75W90 so I am just using it up. I would probably try the 75W90NS with the syncromesh or maybe just the redline 'NS'. The standard 75W90 is just too slippery, everyone who has run it straight has had problems. I have not seen anyone using the NS, why?, i don't know. Just my 2 cents.
Old Sep 22, 2004 | 07:41 PM
  #113
Az3ar's Avatar
I have the NEO 75W90 and shepper said its too slippry so I will be using Pennzoil and will see.
Old Sep 22, 2004 | 07:46 PM
  #114
mttam510's Avatar
i bet it is....Since you are buying oil, try the NS/Syncromesh blend. I would be curious to hear about the results.
Old Sep 22, 2004 | 07:48 PM
  #115
marksae's Avatar
The redline 75W90 gear oil says it exceeds GL5 requirement. I'd keep that stuff far away from the tranny. GL5 oils are corrosive to yellow metals and copper.
Old Sep 22, 2004 | 07:53 PM
  #116
mttam510's Avatar
hmm...good point
Old Sep 22, 2004 | 07:57 PM
  #117
mttam510's Avatar
looks like MTL/Syncromesh would be a much better alt...just read up on the GL5 highly corrosive.....I guess that it is coming back out........
Old Sep 22, 2004 | 10:03 PM
  #118
Az3ar's Avatar
are our trannies GL4 or GL5? and what is Pennzoil? GL4 or GL5?
Thanks
Old Sep 22, 2004 | 10:12 PM
  #119
marksae's Avatar
Thanks
Our trannies require GL4 oils. Pennzoil synchromesh is GL4. More info about pennzoil in this thread:
https://www.evolutionm.net/forums/sh...ad.php?t=72150
Old Sep 24, 2004 | 06:28 AM
  #120
Scooby24's Avatar
Which Redline 75W90? They make several different tranny oils.
Redline MT90 75W90 is good stuff. GL-4.
Do not use MTL. That stuff is Crap. Anything that has a recommendation from the manufacturer saying "Do not use a 100% mixture of this product" cannot be good.
I use a mixture of Redline MT90 and synchromesh. 70-30 mixture. Good stuff.
