EVO in Supercar Challenge takes 2nd!!
Old Oct 19, 2004 | 10:12 AM
  #31
David@Vishnu's Avatar
Originally Posted by Evo_toy
it was bad the CTS can beat an evo thats sux
Ugg people in the know repect the heck out of the new Caddies. They are no joke this weekend at Laguna ALMS/ World Challenge race they were a site to behold. Soon everyone will respect the caddie program
Old Oct 19, 2004 | 10:17 AM
  #32
Hooptie157's Avatar
Originally Posted by Eric Lyublinsky
I have done injectors on WRXs and STI more times then I can count and you don't need to pull the motor but for Cams it's a must.
Eric
Whoops I meant to say Cams. I will edit my post. Thanks Eric
Old Oct 19, 2004 | 10:26 AM
  #33
JTB's Avatar
JTB
Performance wise the Caddies have definitely earned my respect.
The problem with Caddies is that.... they are still Caddies.
They are definitely making strides to improve their image though.
I wonder why there were no Porsches? RUF anyone?
Old Oct 19, 2004 | 10:56 AM
  #34
steve_evo's Avatar
Do you know if Shiv was running 91 oct or Race gas for the tuner event?
Old Oct 19, 2004 | 11:00 AM
  #35
plokivos's Avatar
wasn't that CTS, a type V? with the corvette engine in it? If that's the case, Evo_Toy needs to check himself before posting on lack of knowledge.
it's the LS-6 corvette engine. Here are some stock data for you, Evo_toy:
400 hp at 6000rpm
395 lb ft of torque at 4800 rpm
0-60mph - 4.6 sec
1/4 mile - 13.1
top speed of 163mph
Brembo brakes with 14inch rotors
Tremec T56 6 speed manual
StabiliTrak traction control
Performance tuned suspension
This is a 4 door sedan that weighs about 1000 pounds more than the EVo (3949lb)
So, I don't know why you're disrespecting this car like a fool you are.
Old Oct 19, 2004 | 11:03 AM
  #36
Rules called for 93 oct
Old Oct 19, 2004 | 11:14 AM
  #37
MBGSTI's Avatar
Nowadays cars like Caddys and Benzs have come as LONGGG way...just wait until the CTS gets the ls2 motor soon.
There are STOCK SL65 AMGs runnin 11's@ 125 MPH+ in the 1/4mile that weigh in @ 4500#'s...on 91 octane gas.
Either way a EVO costtin about 50k in total price bein able to keep up or beat cars costin two or three times as much is bad a$$
Old Oct 19, 2004 | 11:20 AM
  #38
siQness's Avatar
there is no way that cost 25,000 is mods, i would say more like 10,000
Old Oct 19, 2004 | 11:49 AM
  #39
CLeeEvo's Avatar
If Vishnu can do something about the 100 to 150 mph time, then the Evo would easily scare the 800hp monsters. That was their only true weakness. I'm guessing a stroker kit should fix that.
Old Oct 19, 2004 | 11:57 AM
  #40
steve_evo's Avatar
Which turbo was Shiv running? GT3037 or GT35R?
Old Oct 19, 2004 | 12:05 PM
  #41
Terry S's Avatar
The 25,000 included installation costs. Shiv had mentioned it was around 17,000 in parts in a previous thread.
The timing device stuck to the windshield came off on the first run while in this section of the race. Paul lost time trying to pick it up and fix it (he figured he'd have more runs to make up for this). However, the IC hose silicon broke up and screwed things up every run after the first. So basically they placed second in the sedan class with a jacked up run.
And the turbo they ran on this was the GT35R, but as I recall, Shiv had said that he would have rather ran the 3071 (or was it the 3037) for this contest.
Hopes this clears some questions up
Terry S
Old Oct 19, 2004 | 12:15 PM
  #42
35R
Old Oct 19, 2004 | 12:19 PM
  #43
Jaylenospoolboy's Avatar
If you read the article you'll see Paul was fishing around for the timing aparatus instead of concentrating on driving, which cost him time.
That was the only run they got because the intercooler hose kept popping off. They completed only one out of five runs.
They ran a 14.86 100 - 150. Comparing their 0-100 which was in the 8's to the other cars which also ran in the 8's, my guess would be the Vishnu number should be at least 2 seconds faster with additional runs, and even faster if more aggressive tuning was possible.
They were running a front air dam and the undertray, partly to lower this number .
Old Oct 19, 2004 | 12:42 PM
  #44
adc's Avatar
adc
R32
WHat about the R32, folks? I don't want to spoil the mood, but that R32 almost matched the Evo's times (at least in a straight line). And because it ran on stock (but tweaked) suspension, it could not match the track times.
My hat comes off to the R32 because it apparently retained a lot of the daily driveability... it's definitely not a bad platform to work on. Would I buy one? Nope, I need a 4 door...
As to the 100-150mph times, a 450 or 475HP car will never beat a 700+ or 800+HP car. Ever.
adc
03 330 PerfPack
Old Oct 19, 2004 | 12:50 PM
  #45
Terry S's Avatar
the R32 did do ok, but remember, this is car had another 20k over the Evo there (a 25k turbo/engine upgrade alone). They spent good chunk more money to still fall short of the Vishnu Evo.
