MR Vortex Generator Air Guide
Old Oct 25, 2004 | 09:39 PM
sp0rk's Avatar
will the MR Vortex Generator Air Guide.....
fit on my 04 lancer railliart ???
Old Oct 25, 2004 | 11:07 PM
sp0rk's Avatar
Old Oct 25, 2004 | 11:08 PM
lookslikeanevo's Avatar
sure why not
Old Oct 25, 2004 | 11:40 PM
Jakeg97's Avatar
Originally Posted by sp0rk
not sure , but it will fit the 03 / 04 evo
Old Oct 25, 2004 | 11:43 PM
negativeB's Avatar
that vortex generator is kinda useless on a small spoiler i think.
Old Oct 26, 2004 | 12:10 AM
sp0rk's Avatar
yeah i know but it looks way tight,
Old Oct 26, 2004 | 01:05 AM
MaxR's Avatar
the VG helps put airflow on the wing through the reduction of CD. Put it on a car with no wing and it will reduce the CD. mitsubishi published a technical paper that explained it to death.
Old Oct 26, 2004 | 07:50 AM
Evolboost's Avatar
Cool thanks for the info. Would you happen to have a link to the technical paper?
Old Oct 26, 2004 | 11:29 AM
Tureno-AE86's Avatar
i want that mr tali lights
Old Oct 26, 2004 | 12:02 PM
sp0rk's Avatar
so will it fit on my ralliart? and since i have a small wing (ralliart wing) will this be bad for my car or help it?
Old Oct 26, 2004 | 12:48 PM
apexernsx's Avatar
How is it attached to the roof?
Old Oct 26, 2004 | 01:06 PM
mike69's Avatar
If you want to see a good, succinct explanation of vortex lift, try http://www.mulsannescorner.com/vortexlift.html that is a pretty good guide to vortex lift.
here is the part you should pay attention to: "Though ultimately vortices could be used for the benefit of top side race car aerodynamics, specifically in drag reduction. Juha Kivekas sums it up best, "It certainly is possible to use longitudinal vortices to fill the wake of the cockpit bulge. This could be done using delta wings on the sides of the cockpit. And actually there have been studies on lorries where angled delta wing were used near the trailing edge of the cab and have been found to increase base pressure; that is, to reduce drag. The vortices steal energy from the main flow and mix it into the wake flow and thus reduce the effective length of the wake. This is Mother Nature's explanation, we simply call it reduced drag"
Old Oct 26, 2004 | 01:40 PM
Joe250's Avatar
MMC Technical Paper
Research on Aerodynamic Drag Reduction by Vortex Generators
http://www.mitsubishi-motors.com/cor...ew/e/2004.html
Lot of really interesting articles. Some pretty technical, some not. Enjoy.
Joe
www.joe250.com
Old Oct 26, 2004 | 04:38 PM
Evolboost's Avatar
Originally Posted by wEstSidE
"The vortices steal energy from the main flow and mix it into the wake flow and thus reduce the effective length of the wake."
That's money right there. Thanks.
Old Oct 26, 2004 | 04:42 PM
apexernsx's Avatar
Again, how is it attached?
