Idea for the Evo: Carbon Fibor fanatics see inside
Old Nov 10, 2004 | 10:24 AM
BADEVO's Avatar
Century - I'm out in Seattle right now, but I'll be home on the 15th. I'll see about rolling up there and hanging out!
Old Nov 11, 2004 | 05:44 AM
Centrylancer's Avatar
cool, i'll pm you cell when you get back eastside
Old Nov 11, 2004 | 07:20 AM
BADEVO's Avatar
Should be home on the 16th. Have a few quick mods to do then, I'm Streetable!
Old Nov 12, 2004 | 01:08 PM
trinydex's Avatar
if you look in magazines of in gt40s posts people already have cold air intakes made of cf. and yes they even have intake manis outta cf... search for it there is a thread about it. also cf does not expand... it's very rigid... more so than steal.
Old Nov 12, 2004 | 02:05 PM
oneguy's Avatar
you do know that CFRP is held held together by plastic and plastic will melt. that is why they don't use CFRP on space shuttle tiles. sorry if that sounded cynical.
Old Jan 24, 2005 | 01:04 PM
got pics yet of the cf piping?
Old Jan 24, 2005 | 02:24 PM
vegasboy301's Avatar
where are the pix
Old Jan 24, 2005 | 05:08 PM
trinydex's Avatar
carbon fiber is not held together by plastic... it's held together by resin... which is a technicality... but significantly different.
also... they wouldn't use anything but the highest heat shielding ceramic in sapce shuttle tiles so i don't even see the relevance of that comment.
one thing that has been brought to my attention lately though, is if you wanna make an intake mani out of cf, especially one that holds boost... you have to worry about shattering, cf is very brittle, hence not too many body panels are made out of the stuff unless you're just pure hardcore.
an intake manifold doesn't need to be made out of the amount of metal that it is for the purpose of holding boost... i mean a dumb example is that a soda can holds quite a bit of pressure with just being the thickness of a soda can, tin cans can withstand a bit of pressure also.
the intake manifold has to worry about boost AND high speed debris, exploding engine parts, corrosion, thermal expansion etc.
it's true that a few of these things can be avoided with the cf, corrosion, expansion etc but in order to contain exploding stuff or withstand high speed dirt and what not... you might have to make a cf mani very thick which isn't hard or a bad thing but... it's just a consideration, makes things expensive.
Old Jan 24, 2005 | 06:01 PM
plokivos's Avatar
BMW Dinan intakes and everything engine cover, tube related is made of Carbon Fiber without plastic structure support, but it's just CF.
It's possible and I think the company that advertise on this site with the carbon fiber ring is making CF intake pipes and few other things.
EvoDan2004
Feb 17, 2017 07:33 AM
DrivenFab
15
May 24, 2016 08:22 PM
mchristian
Dec 8, 2014 10:00 PM
SKILMATIC
Feb 27, 2014 08:26 AM
Fastbreakstar22
15
Sep 11, 2013 06:09 PM
