intake without MAF
Old Dec 31, 2004 | 01:01 PM
J8dailo's Avatar
intake without MAF
im thinking about getting the weapon R intake or the injen intake...and i think either one gets rid of the MAF... when MAF is removed...the engine check light comes on...is there a way to solve that?
Old Dec 31, 2004 | 01:15 PM
Cirrusly Evolvd's Avatar
Yup, convert to speed density with an EMS.
Otherwise your car won't run very well.
Old Dec 31, 2004 | 01:47 PM
J8dailo's Avatar
damn..thats more money i'll have to pay...
Old Dec 31, 2004 | 02:51 PM
evolved04's Avatar
i have a freind with a passat that unplugged the wiriing to the check engine light. you could try that. ha ha.
Old Dec 31, 2004 | 03:40 PM
El Boricua's Avatar
hahahahaha.... lame....
Old Dec 31, 2004 | 11:33 PM
90GSX-03EVO's Avatar
Converting mass air metering cars has never been a cheap process. For a street driven car, you're better off keeping the MAS in place. I seriously doubt you want to have to constantly fool with the settings on a standalone, especially if this car is a daily driver.
Old Jan 4, 2005 | 07:45 PM
DCSilvrEvo's Avatar
Well i had a 1.8t GTI that ran perfect when i put a BOV on and unpluged the maf.Car ran just like it did from the factor with no lean or richness in the fuel system. Not quite lame. Im not really sure if it will be the same for 4g63.
Old Jan 4, 2005 | 07:56 PM
MalibuJack's Avatar
If you disconnect your MAF sensor, without replacing it with something that can read the air volume needs of the car.. it will either run terrible, or not at all..
you have a choice, Keep the MAF, Swap in a blowthrough MAF setup, or convert to speed density.. Keeping the MAF is the cheapest way to go.. Everything else has its share of tradeoffs, some more than others.
But to answer your actual question.. an INTAKE/MAF Pipe kit NEVER EVER removes the MAF, it just replaces the rubber/plastic intake pipe and some kits come with an air filter kit that will replace the air box.. But your stock MAF goes back on..
Old Jan 4, 2005 | 08:06 PM
bluebanana23's Avatar
INjen keeps the MAF
Old Jan 6, 2005 | 10:32 PM
DCSilvrEvo's Avatar
Some ECU's Will switch to the Map Sensors to judge because what if your on the highway and your MAF just goes out. IT happens on the GTI's sometimes and it just switches to the Map Sensors (I Believe) I dont want to experiment until somebody tells me its safe.
Old Jan 7, 2005 | 02:11 AM
...Not on these cars...
Old Jan 7, 2005 | 02:35 AM
plokivos's Avatar
my prelude did that, but I don't think evo does that. I actually ran a bit richer after the maf removal. Didn't effect the performance too bad, it actually ran little bit faster.
Old Jan 13, 2005 | 08:10 AM
DCSilvrEvo's Avatar
Yea I disconnected it the other day and the car started and ran HORRIBLE!
Old Jan 13, 2005 | 08:46 AM
MalibuJack's Avatar
Yeah, try giving it gas and you'll notice the engine has no way of knowing how much fuel it needs, so it just cuts out.. The fact that it even runs is simply a factor of the idle fuel trims.. I've seen these cars run in closed loop once they warm up.. but once you cross that threshold, your done, it cuts out..
the MAF actually has the IAT and MAP sensor, so removing that removes its entire contact with the air anyway.. In order to remove it you would need to convert to a speed density system since its not a built-in "Failover" function of any mitsubishi ECU..
Giuna99
Apr 17, 2016 07:39 PM
evo8426
Jun 28, 2011 12:08 PM
tweaker41
10
May 18, 2011 02:14 AM
plokivos
Dec 28, 2004 11:35 AM
bo0oost
Sep 26, 2004 09:26 PM
