Faster Cold Start
Old Feb 11, 2005 | 10:03 AM
J8dailo's Avatar
Faster Cold Start
im up in the north so its cold up here...and it takes i duno... a good 15 min for the evo to fully warm up...is there anything i can add or do to speed that up? i have to go place to place in a rush many times and the evo can't drive good at all without it being warm..
i heard something about a battery i can get...
Old Feb 11, 2005 | 10:08 AM
mifesto's Avatar
u can always black the radiator partially in the cold same with the oil cooler
Old Feb 11, 2005 | 10:13 AM
evo_whiplash's Avatar
If I need to leave quickly, I usally start it, wait a minute, then hold the rmps around 1800-2000 (instead of the ususal 1500) that helps to get it warmed up quicker.
Old Feb 11, 2005 | 10:14 AM
psionic98's Avatar
our cars could probably have a engine warmer put into them... dunno where though... most new cars come with em for like 25
RallyRedEvo05's Avatar
^^^ I do the same works great
Old Feb 11, 2005 | 01:39 PM
J8dailo's Avatar
engine warmer? never heard of it...where can i get one???!? anyone?
Old Feb 11, 2005 | 02:00 PM
sabastian458's Avatar
very bad idea man, you tring to fry that thing? never ever block the radiator. a person can install a block heater in their car, cheap easy and it just plugs into an 120v outlet. oh dont hold the rpms up like that when it is cold, you will start to hear someone knocking to come out.
Old Mar 8, 2005 | 07:45 AM
J8dailo's Avatar
any working ideas?
Old Mar 8, 2005 | 08:14 AM
Crazy4Cars's Avatar
Originally Posted by J8dailo
any working ideas?
Ralliart Thermostat is your solution.
Old Mar 8, 2005 | 09:11 AM
donour's Avatar
Yes, it takes much longer to warm up on colder days (like this morining). I find that the engine warms much more quickly under light load. Here's my cold morning rountine:
1) start and let idle for about 30 seconds
2) Driving out of my parking garage in first gear at near idle (1000-2000 rpms).
3) Drive the first 1-2 miles in first @ ~2000 rpms. The side streets by my house are small anyway.
This takes about 3-5 minutes and usually gets the engine warmed up enough to run a moderate load and get hot air from the a/c system. They key here is getting some load on the engine. It takes much longer to warm up by just idling. At the same time you don't want to put any serious load on it, nor do you want to get into boost.
d
Old Mar 8, 2005 | 09:29 AM
evo bill's Avatar
Talking
I had this some problem till I moved to south florida
Old Mar 8, 2005 | 09:46 AM
evolute's Avatar
d
this is the best way to do it. even the owners maunal defines warming the engine up as letting the car run until the temp. needle moves. then it specifaclly states that it doesn't matter if you start driving at the first sign of the needle moving or if you wait till it's at normal operating temp.
so just warm it enough to get the needle movin' and go!
Old Mar 8, 2005 | 09:55 AM
2GDSM's Avatar
block heaters isnt the way to go because it doesnt warm the coolant significantly, but it does warm up the oil. Blocking the radiator isnt an option either because the radiator doesnt even come into play until the car almost reaches temp and the thermostat opens. About the only thing you can do is let it idle and do what some have suggested by driving it around at low rpms. I usually drive to 711 to pickup coffee on the way to work, and by the time I'm ready to hit the beltway, the evo is ready to roll.
Old Mar 8, 2005 | 10:06 AM
FinEVO8's Avatar
My local dealer explicitly stated that block heater should NOT be used. Don't know whats the truth, but based on that I wouldn't do it. I find this whole problem quite interesting since up here we've had temperatures WAY below and yet my Evo warms up to normal in about 5 minutes or so. I never warm it at idle, it warms best when you just start driving. It is propably a good idea to keep revs under boost level, though. It also cools down extremely fast! My only complain is that the cabin warms very slowly, I don't like driving with gloves on...
Old Mar 8, 2005 | 10:13 AM
Evoisdream's Avatar
i wake up 9 minutes early everyday and set my turbo timer for 9MIN let it idle for that lock the car up go inside and brush my teeth etc... come back out and go when it hits like 15 sec
evoisdream
