All Part Number Request Go Here
Old Jan 11, 2014 | 06:42 PM
  #4021
ETSRook's Avatar
Don't know a part number. Recently bought 18x10 521 xxr +25 offset. had to put 20mm spacers on the front to clear the breaks. The front wheel pokes about a inch to 2 inches. I researched the evo dave fender push kit. Then also found out Evo Dave went MIA. looking to know if anyone knows anything and could help me out so I can duplicate the kit or maybe buy a kit. Pm me if anyone knows anything. Thank you
-Josh
Old Jan 11, 2014 | 09:01 PM
  #4022
XSilverJ's Avatar
Originally Posted by tsidrift1
Anyone got the part number for the rear floorpan off of an evo 8/9? The actual one that is spot welded to the chassis.
I took a screenshot of the whole floor area cause theirs a few and I wasn't sure exactly which number you wanted.. just let me know which pieces and I can give you the part numbers, the actual floor though (65023) is MR547324
Old Jan 12, 2014 | 08:52 AM
  #4023
tsidrift1's Avatar
Im looking for the rear floorpan which is number 65134, I think.
Old Jan 12, 2014 | 12:51 PM
  #4024
Dragracer187's Avatar
I am looking for the rubber plug, that plugs the timingbelt cover where you can insert the tensioner tool.
Old Jan 12, 2014 | 01:21 PM
  #4025
XSilverJ's Avatar
im looking for the rear floorpan which is number 65134, i think.
(65134) mn150936
Old Jan 12, 2014 | 05:08 PM
  #4026
tsidrift1's Avatar
Thanks a lot man. Do you know by chance, if I were to order a new rear floorpan, does it come with the subframe mount on it already? Im asking as I am trying to piece together stuff to do a mirage to evo 5/6 conversion, and the evo 8 floorpan works perfect. I just dont wanna order a floor pan if I then have to spot weld everything onto it as well.
Old Jan 13, 2014 | 05:27 AM
  #4027
XSilverJ's Avatar
Couldn't tell you man, sorry. Maybe somebody at a dealership or bodyshop could tell you now that you have the part number
Old Jan 14, 2014 | 02:14 PM
  #4028
anyone?
Old Jan 29, 2014 | 12:25 PM
  #4029
k270kmh's Avatar
Difference between fuel pump assy
Hi guys,
I would like to know the differences between these parts:
1760A031
1760A032
1760A190
MN161238
MR954172
http://www.partsbase.org/mitsubishi/...bishi-1760a031
http://www.partswebsite.com/courtesy...-MR954172.html
Old Feb 1, 2014 | 02:00 PM
  #4030
killerpenguin21's Avatar
need the following please:
- right rear lower shock bolt (the one that goes through the control arm)
- o2 housing donut gaset
- o2 housing spring bolts
- front camber adjust eccentric bolts
Old Feb 1, 2014 | 04:36 PM
  #4031
Still did not find this. Anyone that has the number?
Old Feb 3, 2014 | 07:58 AM
  #4032
CaptainSquirts's Avatar
I've been searching all day and I cannot find the part number or the part itself for the Antenna clip that goes on the vortex generator/Antenna.
Old Feb 8, 2014 | 04:29 PM
  #4033
llDemonll's Avatar
Anyone know the part number for the lower bolts on the front shocks? Not the adjustable camber bolt, just the plain 19mm bolt and nut that go with it
#3 in this image:
Old Feb 9, 2014 | 03:16 PM
  #4034
XSilverJ's Avatar
#3 in this image:
The top bolt is the eccentric one right?
If so then here is the bottom bolt and nut
Bolt: MU140067
Nut: MD090875
Old Feb 9, 2014 | 10:11 PM
  #4035
llDemonll's Avatar
correct - bottom bolt is not an eccentric one
you're awesome also, thanks!
