All Part Number Request Go Here
Old Apr 6, 2005 | 09:32 PM
  #481
JustDSM's Avatar
Originally Posted by timzcat
That's odd. Coverted it to jpeg
MR513027
You're not going to like this. That piece isn't avail seperately. That whole thing needs to be ordered together.... Yeah... And its $411.52
Old Apr 6, 2005 | 09:44 PM
  #482
timzcat's Avatar
Ouch, I guess it stays broken for now. I have it propped in fresh air mode.
Thanks
Old Apr 8, 2005 | 10:56 AM
  #483
Russell K's Avatar
Can I please have the part numbers for Drain and Fill Plugs for the Transmission, Transfer Case, and Rear Differential. I found the part numbers for all the gaskets (washers) that match these bolts on the "parts list" you provided, but I couldnt find a part number for the bolts. I also need the part number for the metal screws that hold the undertray on. I found the plastic retainer part number on the "list" so I dont need that number.
Old Apr 8, 2005 | 11:10 AM
  #484
JustDSM's Avatar
I'm out of town at the moment. I'll be back on the 11th. I'll have the numbers for you then, unless someone else answers up before I return.
Old Apr 8, 2005 | 11:58 AM
  #485
Russell K's Avatar
Ok thats fine. The part # MD000312 which is listed as the trans drain plug gasket, transfer case fill and drain plug gaskets does not work on www.mitsubishi-parts.net ? Will you also look that up and see if its the right part when you come back from out of town? Enjoy your time off!
Thanks Alot!
-Russell King
Old Apr 8, 2005 | 12:18 PM
  #486
JustDSM's Avatar
I'm actually out of town for work!
Old Apr 8, 2005 | 01:38 PM
  #487
webguy330i's Avatar
Thanks JustDSM! You own this thread.
Old Apr 8, 2005 | 02:09 PM
  #488
nubby's Avatar
Registered User
What is the part number for the roof skin? It's #30 in this drawing. Any idea what these cost?
Old Apr 9, 2005 | 09:42 AM
  #489
ez76's Avatar
part # ID on the bracket/bolts?
Old Apr 10, 2005 | 07:03 AM
  #490
justchil's Avatar
I'm looking for the part # of the two snap pop things that hold the OEM intake "snorkle" thing to the car.
Also I'm looking for a # on the hose that connects from the valve cover to the intake.. the place where a lot of people use a breather/catchcan
Old Apr 10, 2005 | 07:29 AM
  #491
JustDSM's Avatar
I've got two of those clips. I'll mail them to you if you'd like.
Old Apr 10, 2005 | 11:22 AM
  #492
timzcat's Avatar
Justin, that number for the cooling housing gasket you gave me is the actual housing itself. I just need the gasket.
I also would like that part number for an EGR valve gasket and a PCV hose (cam cover to intake manifold)
Old Apr 10, 2005 | 11:38 AM
  #493
JustDSM's Avatar
Really?! I'm sorry, I'll make sure I pay closer attention. I thought you were asking for the housing. I'm going to be stuck out of town another day. I should be home tomorrow evening if all goes well. I'll reply to everyone then.
Old Apr 10, 2005 | 01:01 PM
  #494
justchil's Avatar
PCV valve hose MN158072
PCV Valve MD152772
Old Apr 11, 2005 | 12:48 PM
  #495
Russell K's Avatar
Could you please provide me with the part numbers for all 4 motor/transmission mounts? I only need the mounts' part numbers and not the brackets they are mounted in unless thats the only way they come from Mitsubishi. I have labeled the parts I need in the pictures provided. I labeled them 1,2,3,& 4. I need these part numbers because I will be working with an individual who might be willing to fill the stock mounts with polyurethane. They need the factory mounts to make prototypes. See this thread https://www.evolutionm.net/forums/sh...89#post1847489 for more details!
Thanks Again!
Russell K
Attached Thumbnails All Part Number Request Go Here-top-drivers-side-mount.jpg   All Part Number Request Go Here-top-pass-side-mount.jpg   All Part Number Request Go Here-lower-mounts.jpg
