All Part Number Request Go Here
Old Jun 27, 2006 | 10:06 AM
  #1126
Smoothgangsta's Avatar
May I please have the part #'s for the following:
2005 RS Trunk lid
+ All trunk lid components (springs, mount bars, lock mechanism)
+ Chrome Mitsubishi Emblem (top center) and Chrome Lancer Emblem (lower left)
Converting my Apex Silver GSR w/ssl over to RS trunk style.
Thanks a bunch!
-Mark
Old Jun 28, 2006 | 06:40 AM
  #1127
EVO8emUp's Avatar
'05 MR Oil Drain Plug/oil temp sensor.
Unlike the regular drain plug (MD050316), this drain plug has the oil temp sensor built into it. I've been looking for this part # for the past 4 months with no luck.
Any help would be much appreciated.
Old Jun 29, 2006 | 08:14 AM
  #1128
TURBevO8's Avatar
OK, can I confirm this?
MR299686 goes between turbine housing and O2 housing
MR404547 goes between turbine housing and exhaust manifold
MR450703 goes between O2 housing and downpipe
MR323654 goes between cylinder head and exhaust manifold
Is this correct? Thanks guys!
Old Jun 29, 2006 | 09:12 AM
  #1129
TURBevO8's Avatar
MR323654 Exhaust Manifold gasket (head to manifold)MD062961 O2 housing to Turbo housing bolts
MN158795 Serpentine Belt – no A/C (RS model)
MN153089 Wastegate Actuator
MD743612 o-ring between transfer case and transmission small
MD727944 O-ring netween transfer case and transmission large
MR266706 Oil feed line
MF660064 Crush washers (turbo side)
MS650013 Banjo bolt (turbo side)
MF650102 Banjo bolt (head side)
MF660063 Crush washers (head side)
MD329503Cam sensor housing cover gasket
MR281085 Lower IC pipe to turbo gasket
MD016483Valve keeper
MD119127 EGR Valve gasket
MN155455 Stock valve cover
MB687014 Midpipe to Muffler gasket
MR464630 Oil cooler
MN143213 Stock boost solenoid
MR475618 Brake Pad Shim set
MR323654 Exhaust Manifold to turbo gasket
^^I copied this off of the first page of this thread. Obviously the same part number cannont be for two totally different gaskets. So all I really need is a confirmation that MR323654 is in fact for mani to head contact and MR404547 is mani to hotside contact.
Old Jun 29, 2006 | 11:22 AM
  #1130
T88H's Avatar
Evo IX HID OEM head lights
Hi I´m owner of a euro Evo IX and here is not available the HID option.I need the 2 parts number of the oem headlights that has the HID included in the headlights(ballasts and bulbs?
I need some more parts to made these change??
Thanks in advance to everybody.
Old Jun 29, 2006 | 01:09 PM
  #1131
TURBevO8's Avatar
I would think aftermarket would be much cheaper my freind.
Old Jul 1, 2006 | 05:57 AM
  #1132
2005 RS Trunk lid
Thanks a bunch!
-Mark
Old Jul 5, 2006 | 05:42 AM
  #1133
scorke's Avatar
MR493288 Can anybody confirm whether or not this is the hardline for the front right, I stripped the flange nut on the hardline and need a new one for the front right, is this the part #?
Scorke
Old Jul 5, 2006 | 07:27 AM
  #1134
Tsurara's Avatar
Does anyone have the part number for the Evolution MR center shifter console? (the console with the ashtray and lighter)
I also need a PN for the caliper pins and the rear seat bolts
Old Jul 5, 2006 | 07:33 AM
  #1135
WarmPepsi's Avatar
Scorke
that'd be the pass front.
I bought both, because of stripping the nut, but haven't swapped them yet.
Old Jul 5, 2006 | 07:48 AM
  #1136
scorke's Avatar
Wait you stripped the nut but just reused it? I was nervous, I attacked the brakelines thinking it was an ordinary 10mm then found out the fast way that 10mm flange nut is far different than 10mm nut.....sh1tty...
Scorke
Old Jul 5, 2006 | 09:05 AM
  #1137
WarmPepsi's Avatar
Scorke
no, the nut is brass, so it deforms easily.
I stripped it, and never even broke it loose. I get the feeling i'm gonna have to drain the fluid out, cut it off, then replace the hardline and hook it to the stainless lines i've had sitting here, but never installed.
I was an idiot and did it to both sides, so the drivers front is gonna be a whole lot bigger pain.
Old Jul 5, 2006 | 06:13 PM
  #1138
boomn29's Avatar
Originally Posted by boomn29
I bought he OE part for the 2003 model, but the plug was different. Looking for a part # (and location for ordering if possible).
250-24227 does NOT work:
https://www.automedicsupply.com/show...nsor=250-24227
Answering my own question. Finally got the dealer to cough it up:
1388A119
List price through the dealer is $380.67 and $100 of labor! lol. If anyone can snag one of these (obviously for cheaper) pm me!
Old Jul 6, 2006 | 11:49 AM
  #1139
thatsMR2u's Avatar
anyone have a part # for the gasket between the oil return line and the oil pan- thanks- nevermind searched and found it - MN156738
Old Jul 6, 2006 | 04:49 PM
  #1140
blonde's Avatar
GUYS!!!!
PLEASE DO NOT PM ME ABOUT PART NUMBERS!!!!! I DON'T HAVE THEM, I JUST CREATED THE THREAD!!!!!
THANKS
Blonde
