All Part Number Request Go Here
Yeah all the copper washers. Thanks
Also I went through the list myself, please let me know if I missed anything and if the part numbers are correct, and there was a typo as well two different gaskets have the same number, I'll highlight them in red
Valve Cover Gasket - MD340535
DP bolts - MR597271
DP springs - MR597273
Turbo - o2 Gasket - MR 299686
03-05 Head Gasket - MN155760
Oil Return Tube (oil pan) - MN156738 (necessary?)
Exhaust Manifold-to-Head Gasket - MR323654
o2 housing-to-turbo bolts - MD062961
Cam Sensor housing cover Gasket - MD329503 (necessary?)
LICP to turbo Gasket - MR281085 (necessary?)
Exhaust Mani to Turbo Gasket - MR323654
Oil Drain tube to turbo Gasket - MR258477 (necessary?)
Head-Coolant Housing Gasket - MD363254 (necessary?)
Keep in mind that I'm doing an o2 housing install, and a cam install, so thats why I'm askin for some other stuff, also if you can let me know the part number for the bolts that bolt from the exhaust manifold to the head. Thanks man you've been really helpful
DP bolts - MR597271
Valve Cover Gasket - MD340535 - Correct
DP bolts - MR597271 - Correct
DP springs - MR597273 - Correct
Turbo - o2 Gasket - MR 299686 - Correct
03-05 Head Gasket - MN155760 - Correct
Oil Return Tube (oil pan) - MN156738 (necessary?) - MR464925
Exhaust Manifold-to-Head Gasket - MR323654 - Correct
o2 housing-to-turbo bolts - MD062961 - Correct
Cam Sensor housing cover Gasket - MD329503 - Correct
LICP to turbo Gasket - MR281085 - Correct and yes
Exhaust Mani to Turbo Gasket - MR404547
Oil Drain tube to turbo Gasket - MR258477 (necessary?) - Correct and YES!
Head-Coolant Housing Gasket - MD363254 (necessary?) - Correct and yes
Copper washers - MF660064 (2) MF660063 (2)
Studs for mani to head - MD005317 (7) and MD146938 (2)
Nuts for above - MR212302 (7) and MR224500 (2)
Washers for above - MD041192 (7) and MD050076 (2)
Don't think so, but if you want to:
O2 to hotside washers : MD132933
O2 to hotside stud : MR224441
Washer for above : Same as above washers
Nut to above : MD050073
Mani to hotside bolts : MN119783
Washers to above : Same washers
Mani to hotside stud : MN119784
Washer for above : Same washers
Nut to above : MD132930
Spark plug seals (should change with vc gasket) : MD186785 (4)
Other than that, you should be good...lol
MD132933 - Order like 10, that will cover you.
O2 to hotside stud : MR224441 : 2
Nut to above : MD050073 : 2
O2 to hotside bolts : MD062961 : 3
Mani to hotside bolts : MN119783 : 2
Mani to hotside stud : MN119784 : 2
Nut to above : MD132930 : 2
thank you.
