All Part Number Request Go Here
Did it ever get answered/added. Worked my way back, couldn't find it.
Anyone know the Evo IX spark plug numbers? Didnt know if this one "MD374841 spark plugs" still applied or not. I plan on trying out the copper plugs and I know that the IX plugs are 1/4" longer. Thanks
Ok i have made a parts list for a little project i have going on so if you could fill in the blanks for me below and maybe double check the part #,s i have already i would really apprciate it. ThanksOEM Evo 8 parts list:
Cam angle sensor assembly
MD344722 - support, camshaft position sensor (basically the sensor body)
MF140025 - bolt, cylinder head flange (qty 2)
MD329503 - gasket, cam position sensor
MD329502 - cover, cam position sensor
MF140204 - bolt, cam sensor cover (qty 3)
MD327107 - sensor, camshaft position
MD375814 - reluctor
MD368730 - reluctor bolt
Thermostat assembly
MN143306 - water inlet pipe
MF140021 - bolt
MD363251 - thermostat outlet pipe
MF140207 - bolt
MN143307 - thermostat housing
MF140239 - long bolt (qty 2)
MF140227 - short bolt
MD363254 - gasket
________ - Thermostat
________ - Water pipe O-ring
________ - coolant temp. sensor
Rear, timing belt shields
MD322517 - upper left
MF140202 - bolt (qty4)
MD334401 - upper right
MF140202 - bolt (qty 4)
MD181864 - plug
MD373065 - lower (no bolts shown)
Misc.
MN143079 - lower timing belt cover
MD310447 - intake manifold gasket
MN163343 - oil pan
________ - oil pan bolts
MD050316 - oil drain plug
MD050317 - oil drain plug crush washer
________ - 2 bolts for turbo oil return flange, oilpan side
________ - water temp sensor
MR578117 - knock sensor
MN100169 - throttle cable
MD180361 - throttle body gasket
MR323654 - exhaust Manifold gasket
MD340535 - valve cover gasket
_________ - front brackets for engine hoist w/ bolts
_________ - rear bracket for engine hoist w/ bolts
also all the nuts/bolts/washers to attach the intake manifold to the cyl. head
99-03 Galant 2.4 OEM parts list:
________ - water pump
________ - oil pump
MD156604 - timing belt pulley
MD308086 - timing belt tensioner
MD182537 - timing belt tensioner pulley
________ - front crank seal
________ - rear main seal
________ - gasket, oil filter housing
________ - coolant overflow resivoir
__________________________________________________
MD375814 - reluctor
Thermostat assembly
MF140021 - bolt
MF140207 - bolt
MD363254 - gasket
MD181864 - plug
Misc.
MN163343 - oil pan
________ - oil pump
interior lights
i have an evo 9 and when you sit inside above the seats you have a dome light... its a long tube like bulb with metal ends.... now the ones up by the window i cant find a regular part number for my life at a part store. its the 3 reading lights under the windshield near the rear view mirror these are plug ins
Plug in ones : MB877458
Hi, I'm looking for the part number for the VIII piston rings. Also, I understand that the IX uses different rings - are the compatible with the VIII pistons (are VIII and IX pistons different?) and what's the part number for these? TIA
Well, I've searched for "inj" in the past 15 pages, and can't find a part number for the Evo8 fuel injectors. Could someone please post it? TIA!
EDIT -- here it is: MN153193
