S-afc2
Old Mar 27, 2005 | 03:29 AM
cyberninja's Avatar
S-afc2
Bought a S-AFC2 and was wondering if anyone has had any considerible gains or any problems. I'm not in the market for a ecu flash. thx for any help
Old Mar 27, 2005 | 04:29 AM
evolvedmb's Avatar
Yeah, watch out for your car stalling!!!!!!!!! Mine has done it about 5 times in the last year. So Leannnnnnnnnnn
Old Mar 27, 2005 | 04:52 AM
trinydex's Avatar
you should get injectors and a pump with the safc. then you can actually tune timing into your car.
Old Mar 27, 2005 | 04:58 AM
EVO8LTW's Avatar
I agree that adding injectors will make a world of difference with an SAFC. I used to have a stock ECU with 660s and just an SAFC. The car felt (no dyno or track results) about as fast as it does now with a mail-in ecu reflash. But you can't get those sort of results unless you tune it with a wideband. Spend the extra $350 to get a wideband and you'll get better results and a much safer tune.
Old Mar 27, 2005 | 09:49 AM
cyberninja's Avatar
I have a fuel pump in my attic. so all i need is the injectors. About what size do i need. And whats not so safe about the S-AFC 2?
Old Mar 27, 2005 | 10:06 AM
mooreboost's Avatar
How can you possibly control timing if you have larger injectors and a fuel pump?
Old Mar 27, 2005 | 12:41 PM
EVO8LTW's Avatar
The more you pull fuel the more you advance timing. If you have larger injectors then you will be pulling more fuel and adding more timing = more power. SAFC is safe if you are tuning with a wideband and scan tool. If you just start just plugging in numbers that you get off the internet, you are taking a big chance of overdoing a good thing.
Old Mar 27, 2005 | 02:23 PM
trinydex's Avatar
the safc is a piggyback... so if you replace the injectors and the pump you're running a more rich and you use the safc to trick the ecu and lean it out, the ecu thinks you're getting by with less fuel cuz it doesn't know any better and you get a timing advance bonus cuz that's what the ecu likes to do.
zenoise
Sep 21, 2012 04:32 PM
turbotool
Oct 30, 2005 05:16 AM
mjev8
Feb 1, 2005 12:37 PM
bpclements
Dec 19, 2003 07:33 AM
evilgixxer
11
May 31, 2003 07:45 AM
