Selling STi/Buying EVO ---Theft Issue
Old Apr 28, 2005 | 03:34 PM
  #31
an0ther's Avatar
all sti's have a chip in the key so if they are getting stolen, there is a fraud suby dealer giving out keys because there is no way to bypass it. I'm sure if there have been some stolen insurance companies are already looking into it becuase its a big deal when a car with chip gets stolen.
Old Apr 28, 2005 | 03:36 PM
  #32
stormhalter's Avatar
^^ Unless they hotwire it or tow it out. Right? Can't a simple hotwire get you past the immobilzer feature?
Old Apr 28, 2005 | 03:38 PM
  #33
twinevo's Avatar
no, hotwire will not work. the only way the average burgler can steal an evo or any car with an immobilizer is to tow it
Old Apr 28, 2005 | 03:41 PM
  #34
Ahh ok. Thanks mate!
Old Apr 29, 2005 | 12:06 PM
  #35
whiteEv0boy's Avatar
No wonder NJ has one of the highest insurance rates.
Old Apr 29, 2005 | 12:12 PM
  #36
BoostWhore's Avatar
Heres what I would do, sometype of engine managment system where it shuts the ecu down so its impossible to make it run. And I would go and spend 500 bucks and have a lojack installed on the car that way if it is stolen the car and be imediately tracked. A nice alarm will help I would add two sirens to make it louder and you can add a pizo siren that installs inside the car put it up under the dash so they cant bare the sound. All thats just a deterent ofcours they could flatbed it away. Theres also a sensor you can get for dei alarms, viper/ pthon samething just different name the sensors reads elevation so if the car is title or anything it would go off. hope that might help
Old Apr 29, 2005 | 12:18 PM
  #37
FlipBoiFlava242's Avatar
Question
Originally Posted by Kordwood
Install a hidden kill switch. $60
whaaat? only 60? where at?...whats a kill switch...
Old Apr 29, 2005 | 12:33 PM
  #38
osunick's Avatar
Only the 05's. The 04's, with the fancy key, actually has no chip whatsoever.
Old Apr 29, 2005 | 12:45 PM
  #39
PapaG's Avatar
You are wrong...the chip can be easily bypassed. It has been documented on NASIOC that a simple paper clip will do the job.
Old Apr 29, 2005 | 12:51 PM
  #40
mike69's Avatar
Yes, you can get passed the immobilizer. I think the kill-switch and Lojack will help, because you just want to make a thief think twice whether or not your car is worth it.
Old Apr 29, 2005 | 01:02 PM
  #41
KevinD's Avatar
a kill switch shouldn't cost more then 15 dollars. if your going to use a fuel pump kill, just buy a 12VDC automotive relay (10 dollars tops) and a two position switch (5 dollars tops). you break the power wire between the ECU fuel pump controller (most likely a relay) and the pump, and you tap your relay betweenthe two. next you attach your two position switch to an ACC+ and to the coil turn-on on the newly installed relay. if you want a diagram when i get out of work i'll sketch one up quickly, but honestly it is very easy.
Old Apr 29, 2005 | 01:13 PM
  #42
Yourmine's Avatar
I used to work for a car stereo shop and when we installed alarms into cars we gave people an option as a secret immobilizer. Believe it or not, but you can actually do something silly as having to push in the cigarrette lighter in in order to start your car, so if you have it out with you, there is no way to start it. Or you can do something like having to buckle up before starting it, or having to turn on your windshield wipers or a turn signal.
Believe it or not, but these things work and we did them for like 45-60 bucks. Check with a reputable stereo shop locally to do that. I used to work for Car Toys in Washington.
Old Apr 29, 2005 | 09:40 PM
  #43
rocketscience's Avatar
this is actually great. I had a friend who had this type of kill switch (on ignition). You had to turn on the headlights and push 1 other button, can't remember which. He dropped the car of at a pay parking lot and forgot to tell the attendant. He couldnt move the car and was a bit pissed when my friend got back to pick it up.
casper3043
Midwest Region
11
Apr 15, 2017 07:48 PM
iLLevo_
Nov 8, 2016 05:17 AM
mrmiller
Mar 14, 2016 11:16 AM
06MRV8Killer
Southeast Region
25
Oct 15, 2015 05:28 AM
Dont Try To Run
42
Feb 11, 2009 03:28 PM
