PUMPING GAS with engine on
Old Jun 8, 2005 | 09:09 PM
  #31
DCSilvrEvo's Avatar
Man I get a CEL And the car trys to stall. First car I have had to do that. Also STALL when a truck passs on the highway.
Old Jun 9, 2005 | 02:20 AM
  #32
rezo's Avatar
Originally Posted by stiklr
fueling up while the car is running is no different than opening the gas cap while the car is just idling. It won't blow up. The car already has fuel in it. Adding more won't make a difference. A cigarette will not ignite fuel, it will ignite fuel vapors though. If you put a lit cig into a cup of fuel, the cig will just go out, no different than putting it in water. But if you sprayed fuel into a balloon and put a lit cig to the balloon you will get a nice fire ball.
or an easy way to remove all the hair from your body... permanently
i wouldnt recommend running your car while pumping gas... is there a good reason to do it other than trying to save 60 seconds by pumping while your tt is running? (plus you can hit a button on your tt to turn the car off)
Old Jun 9, 2005 | 04:54 AM
  #33
WrX Kila's Avatar
Just turn the engine off. It will start to idle bad. Just turn the engine off. You dont want to find what will happen the hard way.
Old Jun 9, 2005 | 05:02 AM
  #34
HiHeatEVO's Avatar
IMO i don't think it's a big deal to leave the car running. environment regulations might have something about it, but i know how screwed up those are. I am a chemist and I am in charge of waste and disposal among other things in my lab.
Old Jun 9, 2005 | 05:26 AM
  #35
MM Racing's Avatar
Have done it on every car I have owned since I have been 16. No CEL ever, the Evo is the only car that actually seemed to get mad when I do it and was about to take it to the dealer for the stupid stumbling problem when filling but evidentally its another normal accorance. If your worried about static touch a light poll near the pump. They are always earth grounded.
Old Jun 9, 2005 | 06:38 AM
  #36
wingless's Avatar
I used to do it all the time with the gas cap jammed in the handle to keep the pump running (in MA they remove the catches on pump handles). For some reason though, it seems to trip the vapor recovery system on the pump and repeatedly clicks off.
It got to be annoying and its easier just to shut it down and the pumps work fine.
mco-evox2008
Dec 20, 2013 09:03 AM
blackevolution8
Sep 25, 2010 08:39 PM
06mr775
Apr 27, 2010 02:54 PM
recompile
May 14, 2008 10:34 AM
4-BNGR
11
Mar 9, 2006 05:00 PM
