Any downsides to running a mini-battery?
Old May 14, 2005 | 12:21 PM
NocturnalEVO's Avatar
Originally Posted by wEstSidE
I see that you can speak Retard. Could I PM you something for translation?
what are u talkin' about?
Old May 14, 2005 | 01:09 PM
Jakeg97's Avatar
Originally Posted by rezo
the stock battery / the one you get when you buy the car / joke / do you get it now?
Old May 14, 2005 | 01:12 PM
rezo's Avatar
yeah got it... thought you were trying to say that he cant change it to a smaller battery or something, just try to make it a bit clearer next time :P
Old May 14, 2005 | 01:13 PM
Jakeg97's Avatar
Originally Posted by alex_alex
the CONs of a smaller battery is that you're stuck with a large size stock one.
you have 2 batteries instead of one. do you understand? having one battery that you dont use... a joke
Jakeg97's Avatar
for you, i will try
Old May 14, 2005 | 02:04 PM
DEVO330's Avatar
Thumbs up
I have had a yellow top Odessy under the hood for a year w/no problems at all. Theres even smaller brands out there nowdays.
Putting the battery into the trunk requires too much heavy cable and the shorter the cables the better for power and electrical inteference.
I start the car with everything turned off just to save juice for a more powerful kick.
I'd give you some pics but don't know how to post 'em.
Old May 14, 2005 | 08:24 PM
TammieNAndi's Avatar
The Evo VI RS-2 came with a much smaller battery than the VIII stock - and I never had any problems even during winter.
Of course if you want to power a monster sound system or you listen to it a lot with the engine off then you would be better off with a larger battery. I did run a small subwoofer and that wasn't an issue neither.
Old May 14, 2005 | 10:13 PM
The reason i want to run a smaller battery kit is so my upper ic pipe has less bends. But will there really be much of a difference between a pipe thats made to go with the stock battery a pipe thats made to go with the smaller battery?
If its not much of a difference i'll just stay with my normal battery and upgrade it to an Optima i guess.
Old May 14, 2005 | 10:21 PM
Derek888's Avatar
most pipes will fit except Buschurs that I know of from the top of my head. They are pretty much all the same size and the the bends are the same, your not going to get less bend from a mini battery. Most get the mini batt for weight savings.
Old May 15, 2005 | 07:32 AM
alex_alex's Avatar
wow, you're really stetching that one. jokes that no one understands are generally really lousy at delivering the punch line. but hey, heres a sympathy laugh
Old May 15, 2005 | 07:33 AM
alex_alex's Avatar
talk to some shops, OTHER than buschur (who sells the pipes), and ask them just how much of a difference the upper intercooler pipe makes. pretty close to none.
nanashi
Jun 7, 2010 08:34 AM
Vibrant
Oct 29, 2008 06:07 PM
tseitz123
Aug 19, 2007 08:37 PM
sandm
Dec 7, 2005 05:03 AM
BOOSTEZ
15
May 11, 2005 03:34 AM
