Evo error code
Old Jul 6, 2005 | 02:07 AM
chakrawal's Avatar
Evo error code
I need all the Evo error code. Thanks.
Old Jul 6, 2005 | 02:37 AM
BuLocal's Avatar
https://www.evolutionm.net/forums/sh...ad.php?t=69304
plokivos's Avatar
I'll be nice today.
DTC P0090: Fuel Pressure Solenoid Circuit
DTC P0101: Volume Airflow Circuit Range/Performance Problem
DTC P0102: Volume Airflow Circuit Low Input
DTC P0106: Barometric Pressure Circuit Range/Performance Pro
DTC P0107: Barometric Pressure Circuit Low Input
DTC P0108: Barometric Pressure Circuit High Input
DTC P0111: Intake Air Temperature Circuit Range/Performance
DTC P0112: Intake Air Temperature Circuit Low Input
DTC P0113: Intake Air Temperature Circuit High Input
DTC P0116: Engine Coolant Temperature Circuit Range/Performa
DTC P0117: Engine Coolant Temperature Circuit Low Input
DTC P0118: Engine Coolant Temperature Circuit High Input
DTC P0121: Throttle Position Circuit Range/Performance Probl
DTC P0122: Throttle Position Circuit Low Input
DTC P0123: Throttle Position Circuit High Input
DTC P0125: Insufficient Coolant Temperature for Closed Loop
DTC P0128: Coolant Thermostat (Coolant Temperature Below The
DTC P0130: Heated Oxygen Sensor Circuit [SEMSOR 1]
DTC P0131: Heated Oxygen Sensor Circuit Low Voltage [SEMSOR
DTC P0132: Heated Oxygen Sensor Circuit High Voltage [SEMSOR
DTC P0133: Heated Oxygen Sensor Circuit Slow Response [SEMSO
DTC P0134: Heated Oxygen Sensor No Activity Detected [SEMSOR
DTC P0135: Heated Oxygen Sensor Heater Circuit [SEMSOR 1]
DTC P0136: Heated Oxygen Sensor Circuit [SEMSOR 2]
DTC P0137: Heated Oxygen Sensor Circuit Low Voltage [SEMSOR
DTC P0138: Heated Oxygen Sensor Circuit High Voltage [SEMSOR
DTC P0139: Heated Oxygen Sensor Circuit Slow Response [SEMSO
DTC P0141: Heated Oxygen Sensor Heater Circuit [SEMSOR 2]
DTC P0171: System too Lean
DTC P0172: System too Rich
DTC P0181: Fuel Tank Temperature Sensor Circuit Range/Perfor
DTC P0182: Fuel Tank Temperature Sensor Circuit Low Input
DTC P0183: Fuel Tank Temperature Sensor Circuit High Input
DTC P0201: Injector Circuit-Cylinder 1, DTC P0202: Injector
DTC P0234: Turbocharger Wastegate System Malfunction
DTC P0243: Turbocharger Wastegate Solenoid Circuit
DTC P0300: Random/Multiple Cylinder Misfire Detected
DTC P0301: Cylinder 1 Misfire Detected, DTC P0302: Cylinder
DTC P0325: Knock Sensor Circuit
DTC P0335: Crankshaft Position Sensor Circuit
DTC P0340: Camshaft Position Sensor Circuit
DTC P0401: EGR Flow Insufficient Detected
DTC P0403: EGR Control Circuit
DTC P0420: Catalyst Efficiency Below Threshold
DTC P0441: Evaporative Emission Control System Incorrect Pur
DTC P0442: Evaporative Emission System Leak Detected (Small
DTC P0443: Evaporative Emission Control System Purge Control
DTC P0446: Evaporative Emission Control System Vent Control
DTC P0451: Evaporative Emission System Pressure Sensor Range
DTC P0452: Evaporative Emission System Pressure Sensor Low I
DTC P0453: Evaporative Emission System Pressure Sensor High
DTC P0455: Evaporative Emission System Leak Detected (Gross
DTC P0456: Evaporative Emission System Leak Detected (Very S
DTC P0461: Fuel Level Sensor Circuit Range/Performance [SUB]
DTC P0500: Vehicle Speed Sensor Malfunction
DTC P0506: Idle Control System RPM Lower Than Expected
DTC P0507: Idle Control System RPM Higher Than Expected
DTC P0513: Immobilizer Malfunction
DTC P0551: Power Steering Pressure Switch Circuit Range/Perf
DTC P0554: Power Steering Pressure Switch Circuit Intermitte
DTC P0622: Generator FR Terminal Circuit Malfunction
DTC P0830: Clutch Pedal Position Switch Circuit Range/Perfor
DTC P1400: Manifold Differential Pressure Sensor Circuit Mal
DTC P1603: Battery Backup Circuit Malfunction
DTC P2066: Fuel Level Sensor Circuit Range/Performance
DTC P2263: Intake Charge System Malfunction
Please make sure you double check with your dealership to verify the code more specifically.
They need to diagnose the code and find out what's throwing the code, since these are the general error codes.
Old Jul 6, 2005 | 02:38 AM
plokivos's Avatar
also there are more, i just haven't gotten those up yet.
will soon, hopefully in 2 days.
http://*********************/forums/showthread.php?t=81
I have upto number 1500
Old Jul 6, 2005 | 02:57 AM
Devbo's Avatar
wow that is alot of typing that wsa real nice of you lol
Old Jul 6, 2005 | 03:04 AM
PoorBoys's Avatar
Wow, a sticky in the engine forum. Good thing we did a search before posting a new topic... Oh wait....
Old Jul 6, 2005 | 03:48 AM
plokivos's Avatar
he's in bangkok, give him a break.
Old Jul 6, 2005 | 03:49 AM
plokivos's Avatar
I think Devbo is stalking me....
Old Jul 6, 2005 | 04:22 AM
aboh6leenz's Avatar
how sweet... in a scary pyhco kinda way...
Old Jul 6, 2005 | 11:18 AM
chakrawal's Avatar
Thanks
Thank you all. Sorry but next time I will use the search first.
Old Jul 7, 2005 | 02:22 PM
Jakeg97's Avatar
very nice list !
besk
Jan 23, 2017 01:05 PM
LSs1Power
Dec 9, 2016 08:06 AM
vboy425
Dec 23, 2007 10:41 PM
hyunkyumee
Mar 28, 2006 10:09 AM
