top speed arguement
Old Jul 19, 2005 | 11:19 PM
4g63powered's Avatar
top speed arguement
Sup guys, correct me if im wrong. Someone mentioned that the evo can hit 180 mph cause they experienced it first hand. I called BULLFECIES! I think the most is maybe 163 +/- a few? Before i open my mouth, it cant, no way in hell possibly even get close right?
Old Jul 19, 2005 | 11:22 PM
ThEyElLoWoNe's Avatar
i beleive its 157 and then the rev limiter kicks in..should be able to find it somewhere.....
Compjoc's Avatar
If a evo has the stock rev limit with stock final drive ratio you'd be right. But rev limit and final drive ratio can be changed.
cass1115's Avatar
well uh fast autos says 157 and here is the link....
http://www.fast-autos.net/mitsubishi...bishievo8.html
Old Jul 19, 2005 | 11:23 PM
_007's Avatar
I swear to you that I have taken the car bone stock after I broke it in, to 160 +/- 1 MPH. I even took pictures with my cell phone. I swear to you 160 MPH was right there. I keeped it up there for about 5 miles.... Let me tell you, you fly by cars really fast. Give your self room....
Old Jul 19, 2005 | 11:24 PM
plokivos's Avatar
170 is highest i've seen in stock, besides the super modded ones.
Old Jul 19, 2005 | 11:25 PM
I done it too. I swear it read 159.9999
grcygetr's Avatar
Best of my knowledge, a stock ECU'd Evo will limit @ 157~ mph. Those flashed can go faster, as the limiter is removed from the ECU.
But, using the happy old theoretical top end configurator...
in top gear:
3500 rpm = 80mph (half of redline) so...
7000 rpm = 160mph ( I knew ratio's would be useful one day!)
anyone else care to add to my silly logic?
naucrx's Avatar
I had my speedo up to 168 once. I've got the stock ECU, but I do have slightly smaller diameter tires.
Old Jul 19, 2005 | 11:27 PM
grcygetr's Avatar
OMG, 7 replies in 3 minutes :LOL:
plokivos's Avatar
it depends on the humidity, temp, elevation, etc.
and stock redline is off by a bit on the tech, and it's 7300 rpm or so is the redline.
Old Jul 19, 2005 | 11:31 PM
Devbo's Avatar
i got mine up to 158 then i got scared and slowed down i donno if i could go any faster
Old Jul 19, 2005 | 11:35 PM
grcygetr's Avatar
We need to rent out the local NASCAR speedway for an afternoon and find out. Anyone near Cincinnati interested in a few top end runs at Kentucky Speedway? :-)
Old Jul 19, 2005 | 11:36 PM
Autoxevo's Avatar
Rev limiter dosent kick in till around 7500, Ive been to 164 at 7100 w just a cat back, still would have gona a couple more (I even video taped the speedo). There should be a governor, but I havent heard anybody find its limit.
Old Jul 20, 2005 | 12:01 AM
QAT-R's Avatar
There isn't a governor on the evos, Just limited by the gear/rev limit, I've seen one hit 191 mph with the usual bolt ons and HKS final drive gear ratios. The STIs are governed don't know at what exactly, a little bit higher than the evo.
