Dyno Results
Old Sep 19, 2005 | 04:27 PM
RazorLab's Avatar
Those curves are horrible and it looks like you have some serious timing pull going on.
What where your AFRs?
Old Sep 19, 2005 | 04:31 PM
djmikeymike's Avatar
could you compare the dyno runs to the ECUplus dyno....... i would like to see if it is accurate..
also if you could post your ECUplus map here i can download it and see all of our settings and the dyno!!!!
Old Sep 19, 2005 | 04:32 PM
joeracer321's Avatar
The dip is from timing being pulled, I have since added some timing in that area, also the curves look bad because the graph is autoscaled, I have a few printouts of the graph on a 350/350 scale and it looks a lot smoother. I can smooth it if you want to, but it doesn't change the results. If I would have had another hour available I could have been able to get all of the tuning I wanted to, but it was simply not possible so the adjustments were made post dyno, and my datalogger shows a much better timing curve now and I have stabalized the two lean spots and one rich spot that I had.
Old Sep 19, 2005 | 04:35 PM
also if you could post you ECUplus map here i can download it and see all of our settings and the dyno!!!!
That is one thing I need to talk to Tom about, I am not sure if my results came out funny because of the way the dyno loads the car but the graph and the numbers came out all whacky. I thought it was the software but I opened another log of someone else's and it looked fine. So this weekend I will go out on a clean road and make another 1/4 mile run to pull a good log and a dyno analysis to see how close it is.
Old Sep 19, 2005 | 04:40 PM
i really really want the ECUplus..... it looks really easy is to tune!! i would like to ask Tom if he has any plans for a separate map for WI so you could have fuel, timing, boost is in the works, and WI........ that would have everything i want!!!
Old Sep 19, 2005 | 04:45 PM
You can have as many maps as you want, you just have to save the maps to your hard drive as the ECU+ holds one map in memory at a time.
Old Sep 19, 2005 | 04:52 PM
i know that, but what i want is another table for WI......
Old Sep 19, 2005 | 06:26 PM
What I usually use for a trigger for WI or AI is a variable voltage switch, which I use in conjunction with my MAP sensor that triggers a relay when x amount of boost is reached. It is the same effect as using a Hobbs switch but much more accurate and super easy changes can be made since the voltage of the sensor is directly related to boost pressure. I haven't installed my AI kit yet but the plans are all drawn up to do it. When I do I will tune a new map and save it for when I plan on spraying Alky.
Old Sep 19, 2005 | 06:35 PM
The numbers I ended up with are great! But what is more important to me is that I went in making 286 Hp and left with 330 HP so even in you call it 250 HP I would have still left with 44 more Hp than I went on the dyno with and it dropped me 4 tenths in the 1/4! Isn't that the purpose of a dyno?
Old Sep 19, 2005 | 06:39 PM
SterlingEvo's Avatar
true... it's good you did a baseline first, because the visibly dramatic improvement is the real story here. Congrats.
Old Sep 21, 2005 | 07:33 PM
Here is a pull on 24 PSI, the result was a smoother overall HP/Tq Curve.
ouminan
GSC Motorsports - Charleston, SC
Jan 9, 2015 10:48 PM
Fourdoor
Midwest Region
11
May 22, 2004 09:35 PM
Fourdoor
34
May 18, 2004 09:32 PM
Fourdoor
18
Mar 6, 2004 09:00 PM
Fourdoor
25
Oct 28, 2003 06:50 PM
