Intercooler spray reservoir leaking
Old Sep 21, 2005 | 07:48 AM
infin|ty's Avatar
I went to go fill the intercooler sprayer the other day and when I started pouring water into it; the water just starting leaking out the bottom, slowly the entire thing emptied itself onto my garage floor. Anyone had this problem before?
Old Sep 21, 2005 | 08:04 AM
krafty's Avatar
Check and make sure the hoses didn't come loose from the connector behind the bumper
Old Sep 21, 2005 | 08:07 AM
yellowmars's Avatar
You sure it all leaked out? It has an overflow hose that causes a fair amount to leak out. It still leaves plenty in there though.
Old Sep 21, 2005 | 08:40 AM
infin|ty's Avatar
Well the liquid is about 7-8" down from the top. None of the water sits in the cylindrical part of the reservoir, I can see some liquid down further once it gets wider...
Old Sep 21, 2005 | 08:43 AM
PA-silver03evo's Avatar
Yes, this is what mine has always done. It should be normal.
Old Sep 21, 2005 | 09:00 AM
mump's Avatar
you can see the clear tube on the side of the reserve. it should drain down that much.
Old Sep 21, 2005 | 09:04 AM
GusandoX's Avatar
you cant fill it past a certain point. its normall that it drains out, just aslong as you check that you can see the fluid about 7-8 inches from the top
Old Sep 21, 2005 | 12:11 PM
donour's Avatar
That tank is a LOT bigger than it looks. Here's a picture off bushur's website.
I doubt it emptied all the way.
d
TxFAkuma
May 5, 2015 01:28 PM
woo9
Apr 29, 2015 12:36 AM
Mauricio Evo IV
Mar 28, 2015 07:46 AM
andrewjb17
Dec 22, 2014 09:14 AM
nor11384
Jul 4, 2014 08:55 AM
