FIRST EVO IX TUNED WITH SAFC2......21psi.....pump gas
What happens when you use smoothing? That spike looks unnatural...maybe an extra 15-20whp just from that big spike alone. I assume this was on 91oct, since it's Cali?
What was the baseline dyno? Without that, it doesn't tell us much yet.
the baseline dyno numbers were not really a concern since that subject has been pretty much beaten to death. the main point was finding out if the afc was still an effective tool with the 9. the numbers were produced on 91 pee water with no tricks employed.
Originally Posted by timzcat
1 question. How does leaving 30 or so ft. lbs. of torque on the table make an AFC an effective tuning tool.
Using a SAFC to tune an evo is like using a sling shot to attack a bear
Originally Posted by DynoFlash
The SAFC is the holey grail of tuning in so cal - its hard to reason with them about the SAFC over there
Originally Posted by Spec'd
The top of this post stated that smoothing was set at 0.
Is that why the graph reads so choppy ?
Keith
If your base line pull was 275HP 263 lb-ft of torque then your tunning with the AFC is crap. If you base line pull was 210 HP and 208 lb-ft of torque then you are a tunning GOD.... so how can you say that the base line does not matter?
Everyone wants to see what other dynojet operators are getting for stock EVO IX's.... why won't you show the graph?
Keith
