SCC's EVO dyno'd
Old Mar 18, 2003 | 01:07 PM
  #211
shiv@vishnu's Avatar
Originally posted by Honky
Hmm.. So if I turn up the bass will that get me in the 12's, or do I also need to adjust the treble?
Just remember to turn the Dolby Surround "off" in the burnout box or you won't know which direction to go when the Xmas tree turns green.
j/k,
shiv
Old Mar 18, 2003 | 01:11 PM
  #212
Originally posted by Hor
You're right, "perfect" was the wrong choice of words. "Very damn well" is more like it. How many cars are in the 10s using your "ECU tuning?"
A few. A local twin turbo Camaro. A stock engine'd Miata. At least two Civics? Pretty much every drag car I have calibrated has either run 10s or 11s. I don't believe any have used nitrous either. Again, this is not difficult. Tuning a car that runs race gas (making detonation all but impossible) and only needs to stay together under 10 seconds of max load (making thermal management a non-issue) doesn't pose half the challenge of tuning a street-driven car to make max possible power, with reliabilty and adaptabilty, on pump gas in any enviroment (driven to work daily or at Thunderhill during the summer, hot lapping for 30 minutes at a time.) I have yet to see any OE powertrain calibrator tune pre-production test mules at the drag strip, running race gas, with expectations of engine overhaul every season.
The hardest thing about tuning a drag car is trying to keep them from overheating tend between dyno runs as they usually run radiators not much bigger than a coffee table book.
Shiv
PS. And Hor, don't mistake my comments about the DSMLink/Fader to be based upon my lack of understanding. I fully understand how it does (and more importantly, doesn't) work. It's not exactly rocket science. If you want to talk tuning, let's do it.
Old Mar 18, 2003 | 01:12 PM
  #213
EVOwhat's Avatar
hehe...Honky made me laugh...
Old Mar 18, 2003 | 01:23 PM
  #214
Hor's Avatar
Hor
Shiv
Interesting. No WRXs? So these were all drag cars though, eh? Can these guys, on their own (i.e with their own Palm Pilot or laptop computer) change their state of tune to make their "drag car" into a "street car?" I know I can.
DSMLink is being used by a bunch of guys doing Autocross and road racing as well. From what I understand, they're really looking forward to the anti-lag feature in DSMLink V2 that comes out shortly. Since I don't have so many twisty roads around me, I'm more of a straight line guy. The stutterbox feature sure is nice, and I'm looking forward to the no-lift-to-shift feature as well.
Mark
"No trailer queen here"
PS. I quoted "Honky." That's why it says, "Originally posted by Honky."
Old Mar 18, 2003 | 01:30 PM
  #215
Running 12s? I certainly hope so! All some of our WRX customers have to do to run 12s on their street car is fill up with pump gas. Palm Pilot not required.
Cheers,
shiv
Old Mar 18, 2003 | 01:32 PM
  #216
Evilution's Avatar
Originally posted by KK
I understand what your saying about complaining about the low numbers, but, I think for the most part, we know those are valid numbers... lower than expected for those on 91 octane, but that's about it.
Agreed.
It seems like you and your friend dynoed on different dynos in different places, so that's not a great example of a dyno not proving anything. I'm sure that results would be far different on the same dyno... that's what I was trying to get at.
Mark
That's the variable I'm talking about on a dyno. Different dynos, location, temp, etc. This is why people need to chill with all the worries about the car being underpowered. If I can run in the 13's with a 100+ trap I'll be happy knowing the car is performing to spec. With only temp and elevation being a factor here it's much easier to tell if your car is underpowered or not. You can get a 15 with a 100+trap and you know your car is still fast. You just suck is all I also believe that finding out the car is running to spec will ease peoples mind on the whole SCC test car having higher numbers and what not. Cuz really who cares if our cars perform to spec? If the test model is what they based their specs off of then yea it's a problem. But if the dealer bought cars perform to spec it's irrelevant what the SCC car puts down. That's my new point
Old Mar 18, 2003 | 01:53 PM
  #217
Hor's Avatar
Hor
Cheers,
shiv
I like that. It was a pretty good little comeback and attempt at skirting the original question. So here it is again, worded in a way that gives you less opportunity to avoid it, since you seem to do that much better than make real power out of any non "drag car." How many cars have you put into the 10s using your own "ECU tuning" (i.e. stuff that you made and designed, not stuff you just resell from Haltech, MoTeC, AEM, or any other company) that can change back to their "street setup" using a laptop or Palm Pilot? As the WRX is the most similar car to a DSM that you do work for, how many of them have you put into the 10s with your special blend of "ECU tuning?" How many of them can change from "drag car" to "street car" with a laptop or Palm Pilot.
Since 10s is obviously too much for you on a non-"drag car," then how about 11s?
-Mark
"Who never said that he was a big dog. 12s are easy."
Old Mar 18, 2003 | 01:54 PM
  #218
Señor Info's Avatar
Originally posted by ShapeGSX
And DSMLink works perfectly.
What makes you believe that your DSMLink will be able to do anything more than log a few OBD-II parameters when hooked up to an Evo's data link connector?
Old Mar 18, 2003 | 01:57 PM
  #219
SpeedKillz's Avatar
2) Two press cars made substantially more power on 91 octane than several production cars, also tested on 91 octane. It's been done before by other manufacturers so it's nothing new.
shiv
Shiv,
Quick question....2 press cars?? I thought there was only the SCC one, now is there another? Thanks.
  #220
Hor's Avatar
Hor
He never suggested it would.
Old Mar 18, 2003 | 02:03 PM
  #221
ShapeGSX's Avatar
Yes, it's still crude. Can you place RPM and load breakpoints anywhere you want (i.e. where they are needed).
A 500RPM resolution is what it offers. That is it. In my experience, I have not seen a reason for greater resolution.
Can you add 1 degree of timing at 150kpa/3200rpm and -3 degrees at 200kpa/3200rpm.
That is handled by the stock ECU's maps (of which there are many for different airflow ranges). The timing adjustment I make is an addition on top of the stock ECU maps.
Does it automatically adjust timing offset to account for the changes that MAF attentuation induces?
You misunderstood the DSMLink functionality. It does NOT attenuate the MAF signal! You are inside the ECU, there is no need to. The stock ECU has a fuel addition on top of the stock maps which is what we call "enrichment." This is what is adjusted. I am using a stock 2G DSM MAF (good for over 450hp unaltered). The MAF signal is not altered. As such, the MAF readings that I datalog are true MAF readings.
We are adjusting the fuel enrichment percentage, which directly affects the injector pulse width.
Does it allow you to determine what load reference (external MAP, stock MAF, TPS) you want to use for your igntion, fuel and boost maps?
I don't know why you would want to use the TPS (well, there is "accelerator-pump" like functionality in the stock ECU based on TPS). As for the other two, the MAF works great unaltered up to 450hp or more. After that, there are options.
Does it allow internal storing of 10 different calibration files.
On the laptop (or Palm Pilot) you can store as many fuel or timing maps as you want.
Does it have a fully mappable built-in water spray control system?
No.
So, did you just indirectly answer my question? What are you working on? Does your product offer streamed datalogging? Does it offer boost, knock, and wideband O2 datalogging? Is the datalogger written in Java, such that it can be modified by the end user? Does your product offer completely user-adjustable rev limits? Does it allow you to change the idle RPM? Does it allow you to set a launch RPM (stutterbox)?
Old Mar 18, 2003 | 02:17 PM
  #222
enthusiast's Avatar
For those of you who want to argue the fact that the DSM link or whatever is a better choice than Shiv, so what?! This thread isn't about justifying your car and your time slips. Most of the EVO buyers are not only interested in getting into the 10s. It is about tuning on the whole.
Besides, I thought we were talking about the discrepency between the SCC EVO and the current ones for sale.
So, leave your personal issues (can't own an EVO, can't drive with the exception of going straight) on the curb, and let the people that actually want to learn from a reputable tuner have a say.
Old Mar 18, 2003 | 02:40 PM
  #223
erikgj's Avatar
Originally posted by Evilution
Agreed.
This is not a different dyno situation, all were tested on shivs dyno same location, different cars. The results were very repeatable. The Dynojet vs Shiv's Dyno Dynamics does not enter into this. No one is saying it is underrated yet. Just that the two press cars he tested had more power by a considerable margin. The SCC car had more power across the rev range.
For drag testing.
That is fine but it really does not test engine flexibility except for a band around peak hp. It is not a good test for power differences anywhere else in the powerband or for drivabilty.
Claudius-
If you don't believe 190hp at the wheels what would you believe and why? Do you believe Vivid Racing's results, that we have 247hp at the wheel and are much more powerful than the JDM cars. Are you trying to argue that point?
Finally to all, instead of attacking Shiv-
Explain to me why we should ignore his reliable, repeatable data. Yet believe traps speeds from drag testing. There are many more uncontrolled variables in drag testing then in Shiv's testing.
Also Shiv has not tried to sell anything as far as I can see here. He probably will eventually but that is the American way. If you don't like his products or service go elsewhere.
Erik
Old Mar 18, 2003 | 03:48 PM
  #224
silvrevo's Avatar
Has anyone thought that the "Ringer" car scc got might just be broke in ALOT better than the production cars with 600+ miles on them.
I personally think 600 miles isnt a good place to start romping on your new car..... even if Mits. says that is the end of the break in period. They probaly dont want really fresh cars trounced on from the get go, right off the lot.
Would it matter more if both cars had the same mileage on them, then put them on the dyno??? Im no tech, or mechanic, but I do have a evo8 that Im planning on breaking in alot longer than the 600 mile period. Ya i have read that to truely break in a car you have to get on it from the get go, but my heart isnt into that.
Just somthing to throw in, if it wasnt discussed before.
And to Shiv. If I was this guy trying to help out on this forum and was treated the way some have treated him, I would have given you guys the bird and left,,,,, FOR GOOD. This guy is brining tons of imfo. and facts to the table. We all should thank him every chance we get. He is a huge plus to this board. Plus if there is a thing here, where they have mislead evo8 buyers in America, Shiv would be able to help and show where this car is not as strong as it is advertised. Which might lead to fixxing the "so called" lack of claimed HP.
Again, thanks shiv for all your thoughts.
Old Mar 18, 2003 | 04:19 PM
  #225
Score's Avatar
Copy and pasted from the other thread:
Grr.
Yes the Evo is a fast car, so is the new SVT Cobra, but guess what? Ford did power robbing things pre-release but fixed them when word got out. Mitsu gave the press a ringer, as fast is the actual Evo is, Mitsu still 'cheated'. If they advertise 271 hp, Id expect 271 hp. Not 270. Blaming the low awhp result on our **** poor gas is no excuse. Mitsu knows that the west coast runs on cat urine and should have accounted for that.
Dont get me wrong, the Evo is a deal, performance wise, but that dosnt give Mitsu the right to snuff the numbers.
/rant.
Edit: This is going by Shiv's dyno, which I firmly trust.
