SCC's EVO dyno'd
Old Mar 18, 2003 | 04:34 PM
  #226
Evilution's Avatar
Originally posted by erikgj
This is not a different dyno situation, all were tested on shivs dyno same location, different cars. The results were very repeatable. The Dynojet vs Shiv's Dyno Dynamics does not enter into this. No one is saying it is underrated yet. Just that the two press cars he tested had more power by a considerable margin. The SCC car had more power across the rev range.
This is exactly the point. There's no "other" data or similar tests from different dynos to prove otherwise. Many on here are afraid it's underrated else there wouldn't be any argument about Mitsu's claims. If noone thinks it's underrated then why ***** about it not being the same as the SCC car?
For drag testing.
That is fine but it really does not test engine flexibility except for a band around peak hp. It is not a good test for power differences anywhere else in the powerband or for drivabilty.
Isn't the point of all this to either A) see why the car isn't making proclaimed 271hp @ peak. Or B) to see why the SCC car is more powerful then dealer tested cars. Regardless of the answer it all points to peak hp. Trying to find out what answer A is would make "engine flexibility" irrelevant. We're talking peak numbers here. Which can be discerned to some extent from drag testing.
Old Mar 18, 2003 | 05:18 PM
  #228
Sweft's Avatar
- His dyno reads lower wheel horse power therefore it is not accurate?
What people here are trying to say is that it might not be accurate per say by number, but when it comes to consistency it is accurate.
Old Mar 18, 2003 | 05:31 PM
  #229
zstryder's Avatar
To quote Shiv earlier,
All the cars we've dyno'd including the SCC car had between 700 and 1000 miles on the clock. The dyno difference between the SCC car and all the other EVOs is so profound that it's almost laughable. It's stronger at all engine speeds, not just above 5500rpm where typical car-to-car, knock control-induced variance has been shown to occur. The torque curve is simply beautiful. It is impossible to dismiss as typical car-to-car variance or standard ECU learning. I'll post up dyno result on Monday comparing it to the other EVOs we've tested.
We have to remember this isn't just 20hp peak, the entire powerband is affected.
On the topic of dynos being "accurate," I think there might be a slight misconception of these terms regarding testing. For one, I don't think chassis dynos are a good indication of hp at the crank to begin with. What chassis dynos are good for, however, are a reliable base whp to work with. Reliable is the key word here. Reliability does not imply accuracy, and that is the key point.
What this means is that Shiv's dyno is reliable, just as any other dyno SHOULD BE reliable, producing consistent results on different vehicles given the same test bed. Hence, we have had multiple Evo's scoring consistently 180whp on his dyno, this is what we call reliable testing. After all, the dyno is a tuning tool, and it better be damn consistent or else you'd never figure out how much net whp you gain from your mods! That's what a dyno does, no more, no less, just using different methods (hence the different types of dynos). Whether this is an accurate assessment of whp or crank hp is something completely different. In fact, I might have to come to the conclusion that knowing your "true" whp is pretty pointless, since it's all relative in comparison. It's about knowing your whp relative to other car's whp, and knowing your whp prior to modding and your whp after modding. With so many dyno and whp standards though, everything's a mess now anyway.
If you are trying to figure out if the Evo does meet the 271hp @ the crank, however, then no matter what chassis dyno you work with you will not always get accurate results. You may get reliable results, which are Evos scoring consistently, but they're not necessarily accurate. For that, you will need an engine dyno.
Old Mar 18, 2003 | 05:39 PM
  #230
shiv@vishnu's Avatar
Claudius,
All your assumptions on drivetrain loss have been based upon years of Dynojet familiarity. Would it be a big leap of faith to, even just for a second, think that driveline loss for a stock EVO (and other cars, of course) is indeed that significant. Before you say "absolutely not", I'd encourage you to spin an entire, fully loaded drivetrain, with wheels/tires/brakes, etc,. up to 7500rpm/100mph and report back your findings.
Considering an AC compressor can be parasitic up to the tune of 10 wheel hp, an UD pulley can free up 10 wheel hp, heavier wheels can cost 5-8 wheel hp, and so on... just think what gears, a few differentials, a three-piece driveshaft, four heavy rotors, four axles, lots of frictional losses on the tire/roller interface, etc,. can do when all added up.
Cheers,
Shiv
Old Mar 18, 2003 | 05:47 PM
  #231
evo_dan's Avatar
Originally posted by Claudius
Please tell me you understand what I mean, I'm going crazy here
Dude, the way I understand you drive your car through the back roads, I'd say you've been crazy for a while.
Old Mar 18, 2003 | 06:33 PM
  #232
ShapeGSX's Avatar
Originally posted by shiv@vishnu
PS. And Hor, don't mistake my comments about the DSMLink/Fader to be based upon my lack of understanding. I fully understand how it does (and more importantly, doesn't) work. It's not exactly rocket science. If you want to talk tuning, let's do it.
Is it just me or did I just have to explain it to you? You thought it modified the MAF signal.
Old Mar 18, 2003 | 06:54 PM
  #233
theheff's Avatar
Shiv, would it be possible to post a comparison of the SCC ringer car to the dealer cars? I, for one, would like to compare the discrepancies, not only at peak, but also throughout the RPM range. (i.e. the dyno graphs on 91 octane)
keep up the great work and please ignore the haters,
heff
Old Mar 18, 2003 | 06:57 PM
  #234
wrx-vs-evo's Avatar
to shapeGSX
This board is too hectic and fast to follow.
I've only read some of what ShapeGSX has written. What's your stand on the USDM EVO again?
I mean are you getting one?
Do you own a tuning shop that's planning to work on the EVO?
How does your DSM tuning knowledge apply to the EVO? 100% compatible?
I'm interested in seeing some results, say a EVO8 tuned by your philosophy. Post up a dyno on it and let us be the judge on it.
I'm not interested in time slip as evidence of tuning supremacy. Hey if 0-60 and 1/4 mile is your thing, that's wonderful. For the avg joe a smooth 300hp ish car will suffice.
Will your tuning methodology be reliable for a street driven car. I'm sure most of the EVO owners would like to enjoy their 30k+ car for long while.
Old Mar 18, 2003 | 07:05 PM
  #235
KK's Avatar
KK
EvoM Administrator
The problem is that no other tuner has gone to the lengths that Shiv has testing the Evo. I also doubt any other tuner will be able to get their hands on the press car for dynoing either. Again, this isn't about the Evo being underrated, but it's about the press car making 20 whp more across the entire powerband. Many of us want to know why that is because that car is to be tested by the press and if it's nothing like our own Evo, then those impressions and test results are bogus. That doesn't mean much for our actual Evos, it's a matter of principal, at least to me.
The answer won't point to peak power on a drag strip, the answer points to ripping that engine apart to see what may be different from our own cars. Anything else can only lead to assumptions. Based on Shiv's well tested dyno results, many of us believe there is something different in the press car. We'd like to know what that is. The rest of these discussions are just rants/concerns/arguments/debates/etc.
Mark
Old Mar 18, 2003 | 07:12 PM
  #236
KK's Avatar
KK
EvoM Administrator
Re: to shapeGSX
I'd like to know, too. So far you, Hor (especially), and a few others have come off confrontational and sarcastic at times. I'd much rather see posts/debates leading to contributions then personal battles as we're getting right now. Your tuning techniques work great for you, but not everyone will be following those methods, so please understand that, and if you feel you have something to contribute, please do so... just less hostility... all of us.
Mark
Old Mar 18, 2003 | 07:13 PM
  #237
Ben's Avatar
Ben
What gets me is you guys who are bashing Shiv's tuning abilities with the EVO when he hasn't even released any products for it yet. If it works out like I think it will, his products will end up getting significant gains for the EVO and all of your attaks will end up looking pretty stupid. Must be some underlying resentment or something. Why would you want to drive somebody away from providing products for the EVO. Just means more competition and better prices and options for the consumer. If you've got a problem with him, don't buy his products. I'm sure plenty of people here appreciate what he is working to do for the EVO.
Old Mar 18, 2003 | 07:20 PM
  #238
theheff's Avatar
All we are saying...
Try to see it Shiv's way,
does he have to keep on dynoing
till he can't go on...
we can work it out
we can work it out
heff
Old Mar 18, 2003 | 07:24 PM
  #239
zstryder's Avatar
I think if everyone just stayed on topic instead of raining on other ppl's threads, then everybody would be happy. For the haters or disbelievers, just ignore the thread! If we wanted your opinion, then we would have asked. Simple as that!
What a great solution I've come up with.
Old Mar 18, 2003 | 07:28 PM
  #240
TearItUpSports's Avatar
I just think there are too many people are here that are not getting laid.
