JDM EVO MR Headlights on an RS?
Old Jan 18, 2006 | 08:42 AM
OBTUR8's Avatar
Question JDM EVO MR Headlights on an RS?
I bought some of these and took them to my mitsubishi dealer to install and they said it would not connect up to the existing wire harness on the car......WTF?
Anyone know what I should do, I tried doing a search, but no luck.
Old Jan 18, 2006 | 08:47 AM
EVIL_EVO_VIII's Avatar
Yeap you cant do it, the wiring harnesses are different. What you can do is get an aftermarket HID kit with DS2 bulbs and it should work.
MIevo8MR's Avatar
Not exactly sure if this is what you're talking about, but I know that you need this connector to use the JDM headlights on USDM evos.
http://www.lancershop.com/customer/p...?productid=680
Old Jan 18, 2006 | 08:50 AM
RRRS's Avatar
RS lights = 9006 lo beams, 9005 hi beams, no fogs
JDM MR = D2S HID lo beams, 9005 hi beams, 9006 fogs
you need to get a HID set and proper harness, check xenondepot.com.
Old Jan 18, 2006 | 08:55 AM
OBTUR8's Avatar
I actually have the McCulloch HID kit w/ 9006 bulbs, but I knew ahead of time I would need D2S bulbs, so I ordered them, but they did not hook up to the ballasts (there were no wires coming off the light bulbs like the 9006's). The other problem was when the mechanic took me out to the garage to show me, It wasn't just a problem with the low beams, he said it would also not work for the turn signals, etc because they also had different harnesses.....he said what he could do is take the wiring off my existing lights and put it on the MR lights, but that did not give me a warm fuzzy feeling. I'm so pissed.
Old Jan 18, 2006 | 09:01 AM
alloyic_rs's Avatar
what exactly IS the difference between the RS lights and MR lights, is it just the looks? if it is then cant you install a HID kit on the RS lights?
the rs lights have a spot for fog bulbs but dont have a bulb
Old Jan 18, 2006 | 09:05 AM
OBTUR8's Avatar
Looks and the beam pattern will be different...I do have 8000K 9006 bulbs in my RS headlights right now, I just wanted to switch to the MR headlights mainly for looks, but I wasn't expecting this....according to Lancershop.com, they are plug-n-play for the RS.....whatever
Old Jan 18, 2006 | 09:10 AM
I made the same mistake of buying the HID kit with 9006 bulbs, i dont want to get another HID kit and waste my money.. I suggest to sell them or return them to lancershop if you can and send the headlights to EvoDave
Old Jan 18, 2006 | 03:29 PM
OBTUR8's Avatar
What can EvoDave do??
Old Jan 18, 2006 | 04:14 PM
Gruppe-S's Avatar
Hi,
The regular projectors are not meant to be used with HID bulbs. The beam pattern will be scattered when an aftermarket HID kit is installed. We have the JDM Evo 9 headlights with the OEM factory HID for sale right now and this might be something you should consider.
A link to the headlights:
https://www.evolutionm.net/forums/sh...d.php?t=179422
Thanks,
Tom
Old Jan 19, 2006 | 08:52 PM
OBTUR8's Avatar
Why can't they just make it easy to swap lights out.....everything has to be a major PITA!!!
flyinmonkey101
30
Dec 27, 2016 08:46 PM
Nicksega
Lancer How Tos / Installations
Jul 11, 2016 09:50 PM
impact blue
Mar 18, 2016 09:54 AM
OZRally462
Lancer Engine Tech
17
Jun 8, 2014 12:21 PM
newevoxguy
Aug 23, 2013 02:55 PM
