Engine Blown Mitsu will not cover repairs HELP.
Old Feb 9, 2006 | 11:24 PM
  #121
2hot2handle's Avatar
Originally Posted by PurgeIt
Hahah... Here's what I wrote:
"I smell bull****. So you left in a non-Honda ECU and they were totally cool with it eh? And you used a N/A ECU with a turbo? interesting..."
Honda does not = Mugen. Mugen is NOT Honda. Is that hard to comprehend? If a Honda dealer checked out your car as you claim, they would have immediately noticed that the propoer ECU is NOT in the car. Ding... no dealer in their right mind would warranty a blown motor especially when the telltale signs are there that you messed with it.
Number two... Mugen DOES NOT make ECUs for turbo applications, ONLY for N/A. So how did you run a N/A ECU on a turbo motor, specially when so many parameters are completely different for a turbo set up?
With a V/S-AFC? As I said... any moron who does even a little bit of research on HOW the APEXi units work knows that it's completely ineffective and uselss on speed density / MAP cars.
So tell me... how do you tailor a non-programmable ROM-based N/A ECU to work with a turbo application?
+1
Old Feb 9, 2006 | 11:35 PM
  #122
lazyevo's Avatar
you know how mitsu is, they treat you like a king at first until you need that cel light to go off then they act like they don't even know you. good luck, but with the mods i dont think luck has anything to do with it. sorry man
Old Feb 9, 2006 | 11:37 PM
  #123
lazyevo's Avatar
Old Feb 10, 2006 | 05:17 AM
  #124
4ringturncoat's Avatar
Originally Posted by Karma'sEvo
WHAT ARE YOU TALKING ABOUT HE HAS ALMOST NO MODS.. LEARN HOW TO READ
Boost controller and a SAFCII...no mods...learn what those parts can do on their own or in conjunction with each other before you make a dumb*** statement like that again! And remove the ALL CAPS typing...
Old Feb 10, 2006 | 05:23 AM
  #125
forbidden color's Avatar
Originally Posted by TTP Engineering
I am dizzy...
That is all I can literally add.
lol i actually just read that too. I think i was really tired last night.
what I was trying to say was that you can't overboost on the stock ecu.
but usually if the piston isn't cracked - detonation, and is melted, then it's usually it's drivers fault for abusing the hell out of it.
but I'm sure someone will argue this point and I would really like to hear about how this could exactly happen.
Old Feb 10, 2006 | 05:29 AM
  #126
on the mugen part, actually it's interesting because Mugen could very much be Honda or they could get whatever they want from Honda.
Hirotoshi Honda, who owns Mugen is the son of the late Soichiro Honda, the founder of Honda automotive group in Japan.
Mugen does basically all the aftermarket research for Honda. Like your average wings and what not.
Old Feb 10, 2006 | 05:32 AM
  #127
Ph3n1x's Avatar
Ironic how you put a B/C in to save on gas when its made for the car to go faster andnow you gotta spend 14000x times more on the car.
Old Feb 10, 2006 | 05:39 AM
  #128
Happy Madison's Avatar
Originally Posted by SKILMATIC
Now you are refurbishing what you said after I just called BS on you.
congratulations. you are now officially the dumbest person on evoM.
Old Feb 10, 2006 | 05:45 AM
  #129
gunnar's Avatar
That Blows!!!
Old Feb 10, 2006 | 06:10 AM
  #130
I don't know why you would think you have a case. This is all you. Sorry.
I am saying he put the two most "likely to blow up your engine" parts on his car and because of that he needs to get out his checkbook to pay for a new motor. I personally think he should pay for it.
Old Feb 10, 2006 | 06:22 AM
  #131
Evoryder's Avatar
just so you guys know.... the profec has a real time boost display and peak last boost(stored)...maybe you should check your max boost....but if your wastegate was cut(or torn) then he wasn't using a profec....so to speak. I use my profec b as my boost gauge....very accurate.
we all pretty much know what happened to his car...lets just hope he learns and moves forward. Lets not beat on this dead horse...i want to hear some positive feedback of "i got my car back together and i'm gonna keep her" ...you getting rid of an evo is like being rich, divorced and not having a prenup lol
Old Feb 10, 2006 | 06:30 AM
  #132
sabastian458's Avatar
Talking
I have been able to acheive 28 psi on a factory evo before, but granted I had to physically disconnect the wastegate and keep it closed. (which I don't recommend doing) and that was only done twice.
Old Feb 10, 2006 | 06:33 AM
  #133
rudebwoyt, if you have to purchase a new engine, let me know what you want for your block. I am looking for one to do a strocker. Also, which dealer do you have your car at? I know the guys at Dayton Mitsu work on Evo's alot and maybe able to help you out some way.
Old Feb 10, 2006 | 06:35 AM
  #134
PVD04's Avatar
SKILMATIC,
Please stop posting incorrect information in this forum. In all likelihood, you will have to pay for a new clutch every 10,000 miles, a new engine at least once, and probably a new transfer case. This has nothing to do with the quality of the Evo, but that you appear to have very little understanding of how a car works. Your posts have not benefited this thread in any way.
To the creator of this thread,
Unfortunately your engine problem was likely caused by your tuning of the SAFC. The only other likely possibilities based on the information you provided is a fuel pump or injector failure. It is an unfortunate situation, but when you begin modifying boost pressure and A/F ratios it is difficult for a manufacturer to accept responsibility for an engine failure. Your best bet at this point would be to try to source a used motor from someone, as that is the cheapest option. Buying a new motor from Mitsu is probably the most expensive option, and getting a built motor from one of the shops on this forum would fall somewhere between the two.
-Paul
Old Feb 10, 2006 | 06:42 AM
  #135
robertrinaustin's Avatar
From: Work - New York, Alaska, Mexico or the Caribbean. -Home - Tx Hill Country
Check out the RNR stroker. The price was right and didn't require a good core.
