Launch Control
Old Mar 1, 2006 | 11:11 AM
  #46
SilverNine's Avatar
[QUOTE=Warrtalon]Yes, all 05s and 06s have this built-in 5k launch limiter that inadvertently behaves like a 2-step launch control. Yes, it also builds boost (~5-7psi).
Also, you can get launch control with a Dynoflash, and you can have the RPM set wherever you want. The default RPM is 6k rpm, which is where mine is set in this video:
Dynoflash 2-step launch control (6k rpm)
It was discussed in this thread:
As requested, here's a vid of my 2-step Dynoflash launch control
With the 6k limiter, it builds 10-12psi, but I would not recommend using it too often with a cat, though.[/QUOTE]
hey, quick question.... y do u not recommend using it too often with a cat??
Old Mar 1, 2006 | 11:14 AM
  #47
Warrtalon's Avatar
THe extra fuel in there could destroy the cat. This 2-step is really not for everyday use. It is only for serious racing applications, so I am hoping people don't just get it to go play around with on the street.
Old Mar 1, 2006 | 11:30 AM
  #48
M3this's Avatar
From: Where you come to vacation and go home on probation! Vegas!
Originally Posted by cloudy
That would mean youre slipping the clutch way to long.. When we say slip that doesnt mean let it out in a matter of minutes. But dont pop it. "Slow pop it" if you want to call it that.
So are the 06's just set to 5,500? Or is my car just some odd ball?
No I wasnt slipping it long ... I know this entire thread makes me seem like I dont know how to drive but really I do ... I slipped it quickly and the clutch just slipped
Old Mar 1, 2006 | 11:34 AM
  #49
cloudy's Avatar
Idk what youre doing exactly, everyones definition of slipping and dropping could be different, but try this then. Basically just slip the clutch till you feel your car grab the ground, then drop it likes it hott.
Old Mar 1, 2006 | 11:37 AM
  #50
SilverNine's Avatar
so with a test pipe u can do it often, or do u still have to be careful and limit the # of times u use it at the track?
Old Mar 1, 2006 | 11:43 AM
  #51
Warrtalon's Avatar
With a test pipe, there is no issue.
Old Mar 1, 2006 | 01:38 PM
  #52
shivaswrath's Avatar
what the bloody hell,
I'm pissed now,
the 06's ALL get the teflon coated shifter cables AND launch control at 5.5k???
I hate my 5k limiter, i confused the ECU ONCE and i launched at 5.3k, it was utter beauty. . .
So that's why '06's bone stock are clocking higher reaction times. . .this is making more sense. . .Warr, how much boost is one making at 5.5k versus 6k?
Old Mar 1, 2006 | 01:46 PM
  #53
TTP Engineering's Avatar
About 7-8psi max.
Ours is at 5652 rpms.
Old Mar 1, 2006 | 01:52 PM
  #54
SilverNine's Avatar
According to Warrtalon, at 6k RPM u are at about 10-12psi... so at 5.5k RPM... im guessing it should be around 8-10psi
Old Mar 1, 2006 | 02:03 PM
  #55
According to my medical grade boost sensor and $700 logging equipment, it allows me not to have to guess.
Old Mar 1, 2006 | 02:41 PM
  #56
Warrtalon's Avatar
I'm pissed now,
This has no bearing on reaction times, however, it may be allowing 06s to get better 60's without having to disconnect the launch limiter switch.
Old Mar 1, 2006 | 02:43 PM
  #57
evozakk's Avatar
so does a basic dynoflash change it (for 04) or do you have to request it
Old Mar 1, 2006 | 02:48 PM
  #58
Warrtalon's Avatar
It's automatically included in any Dynoflash now and is set to 6050rpm unless otherwise requested elsewhere.
Old Mar 1, 2006 | 02:52 PM
  #59
evozakk's Avatar
^thanks, i need a flash- (i have the afcII and dont really like it)
Old Mar 2, 2006 | 08:09 PM
  #60
Evoryder's Avatar
jsut watched the warr vid again.... "fire crackers"
seascooby
AEM EMS
Oct 12, 2014 09:08 AM
Mikeodeth
15
Apr 28, 2014 07:31 PM
audiofan
Apr 3, 2011 05:36 PM
00cls1camaross
Driving Techniques
Aug 8, 2008 01:33 PM
sekula
Sep 13, 2007 01:47 PM
