Clutch Shudder When Cold
Old Mar 5, 2006 | 05:16 PM
SOLO2M3's Avatar
The Evo is an '05 with 11,500 miles on it and is 7 months old.
When the car is cold (it doesn't get real cold in Texas) I noticed a clutch shudder when releasing the clutch. No noises, I just feel it. It seems to go away after a 15-20 minutes of driving although I occasionally feel a slight shudder after it's warmed up.
The car has had a *few* hard launches at autocross. That is if you can launch hard with the stupid "clutch in rev limiter" that '05's have. I have noticed no slipping at all.
Is it time to shop for a new after market clutch?
If it is what do you guys recommend for a car that's used as a daily driver and weekend autocross weapon?
Thanks
Old Mar 5, 2006 | 05:36 PM
rburris28's Avatar
Thanks
I have this same problem, and if it's a mild shuddering only when cold and only at low rpm, it is probably a warped flywheel. I got mine at one autocross as the clutch was going out.
For me, the stocker is the way to go- it prevents me from breaking anything in the drive train, has good feel, and I'm use to it. I can't see changing it unless you're going for more than 300 WHP.
Too bad mine only lasted 15,000 miles.
Old Mar 5, 2006 | 07:00 PM
oak2207's Avatar
I have 46k on my '03 and it's done this since day one. You just need a little heat in the clutch and then it'll go away. I'm still on the stock clutch and it's holding fine. In the mornings I just slip it a tad more for the first few get goes and then it's a-ok.
Old Mar 5, 2006 | 07:03 PM
Jeller's Avatar
Mine does it too, especailly when it like 10 degrees out here in Buffalo NY. It goes away once it warms up, I am not worried about it.
Old Mar 5, 2006 | 07:05 PM
oak2207's Avatar
Yeah no doubt, I feel that pain... Luckily it's been pretty warm in CO for a while.
jfLip's Avatar
Mine does that, too. But sometimes there's a humming noise... But, after getting warmed up it goes away. Is my clutch fine?
Old Mar 5, 2006 | 07:32 PM
4TUN8's Avatar
Mine did this right before it left this world for a better place (hanging in my garage, ouch)
Old Mar 5, 2006 | 08:11 PM
speedracer2169's Avatar
ok I'm in so cal and i get this sometimes when it's cold and occasionally when warm too, Do I need to just have the flywheel resurfaced?
Old Mar 5, 2006 | 08:43 PM
Jasil's Avatar
The humming is the throwout bearing..does it go away when you push the clutch pedal in?
Old Mar 6, 2006 | 06:03 AM
althemean's Avatar
23k on mine and it does the same thing when its cold. Always goes away. I wouldnt worry about your clutch until it starts slipping.
From what I hear, those Exedy Hyper Singles do it right out of the box. One of the girl members on here has one and she says its pretty loud.
Old Mar 6, 2006 | 06:11 AM
gsrboi80's Avatar
same here I dont worry about crap like that cause itll drive you crazy. I just chalk it up to ownig a performance car.
Old Mar 6, 2006 | 06:19 AM
Greg K's Avatar
like everyone else says, it's normal. My 05 MR has done it in the cold since day 1. If it's any consolation my dad's 2001 M5 shudders in the cold too.
Old Mar 6, 2006 | 06:28 AM
negativeB's Avatar
https://www.evolutionm.net/forums/sh...ad.php?t=36751
it's normal.
Old Mar 6, 2006 | 12:28 PM
SOLO2M3's Avatar
Guys, thanks for the advice.
I guess this is normal so I'll just go flog it and have fun.
Old Mar 6, 2006 | 12:39 PM
IluvBoost's Avatar
Ya I live here in Cincy and sometimes we get those cold days and mine does this as well.
kamakazy_kid
May 2, 2012 02:01 AM
prowakeskater
Apr 22, 2011 09:47 AM
MITVRX
Dec 3, 2007 02:41 AM
bigjhoney
Apr 3, 2005 03:40 PM
DEL TURBO
Sep 15, 2004 07:36 AM
