*Quick oil question!!*
Old Mar 9, 2006 | 12:56 PM
  #31
Turbolover's Avatar
MOBIL 1 SUCKS NO MATTER THE WEIGHT OR TYPE. END THIS DISCUSSION!!! ALL U TIGHT AZZ'S SPEND A DOLLAR/QT. MORE AND UPGRADE TO RP,REDLINE,AMSOIL, ETC. AND DO UR MOTOR A FAVOR. PLUS ALL THOSE MOTOR OILS MENTIONED WILL BLOW MOBIL-1 OUT OF THE WATER AND LAST A HELL OF LOT LONGER!!!
Old Mar 9, 2006 | 12:59 PM
  #32
Danny23's Avatar
What Makes You Say That, Have You Had Any Bad Experiences With Mobil1?
Old Mar 9, 2006 | 01:04 PM
  #33
Turbolover's Avatar
mobil-1 was in my car for 1500 miles, then i switched to redline(my personal pref.)
mobil-1 is the bottom of the barrel synthetic. if u plan to drive ur evo under normal conditions and hardly any boost, then ur a life long mobil-1 supporter. but if u demand more from ur car upgrade and . also, if u plan to go longer between changes, upgrade.
Old Mar 9, 2006 | 01:17 PM
  #34
Danny23's Avatar
Again I,d Like To Know Why You Think Mobil 1 Is At The Bottom Of The Barrel. There Has To Be A Reason You Dont Like It
Old Mar 9, 2006 | 01:27 PM
  #35
TxEvo8's Avatar
Originally Posted by Danny23
the bearings get hotter without a cool down after hard running and boostin. and that turbo spins more like 100,000 rpm,s not 20 -30k. if you let your car run or get a turbo timer what your doing is maintaining oil to the turbo bearings during turbine slow down and keeping them cooler and lubed
I've read under full boost, our turbos can reach 150k rpm...
Old Mar 9, 2006 | 01:35 PM
  #36
ZK's Avatar
ZK
Nothing wrong with Mobil 1 Extended Performance. I wouldn't go the extended drain intervals it's advertised for because I like my oil to be fresh and clean but it should be perfectly fine for your car.
The EP has more detergents in it to make it last longer when you change the oil less often - not worth the extra cost to me since I change it every 3K miles or after a track event anyway. Again, like I mentioned before - it is fine for your car. I ran it before when I didn't see the normal Mobil 1 at the store.
I think someone probably got confused with the Mobil Clean Extended line or something.
Old Mar 9, 2006 | 01:36 PM
  #37
forbidden color's Avatar
I agree with amsoil. Amsoil is really good and they've done an extensive studies on synthetic oils for a long time and published the results.
Old Mar 9, 2006 | 01:57 PM
  #38
Danny23's Avatar
This Subject Has Been Beaten To Death. Amsoil, Royal Purple , Mobil1,etc. Are All Excellent Oils And Can Be Used In Our Beloved Evos With No Worry
Old Mar 9, 2006 | 02:00 PM
  #39
Qmr's Avatar
Qmr
Since this is quick question about oil, do you guy change oil of your evo after break in? at ~ 800miles or when is the first time you guys change oil?
Old Mar 9, 2006 | 02:17 PM
  #40
Joey B's Avatar
Veteran: Air Force
Wow....you guys need to calm down. If you really want to learn more about oil go to www.bobistheoilguy.com
After being on this site for more than a year and a half I've learned quite a bit from guys that test their oils all the time. So here is some info I've got from the site and the rest you can search out more if need be.
BEFORE the M1 extended (ext) there was just regular M1. Now, the older regular M1 had a set detergent package in it. M1 ext now has that detergent package in it and the NEW regular M1 has a slightly less detergent package in it.
What does this mean to you? The old M1 you were buying has been retagged to M1 ext. How did the site find out? From guys sending in fresh oil samples of the old regular M1, the M1 ext, and the NEW regular M1. There are a lot of guys on this site that use oil tests religiously to see at what point they need to change their oil because of break down. Typically what I've seen on there is anywhere from 5,000 - 15,000 NA or forced induction engines before the oil even starts to break down (they do change their oil filters, just the oil).
If synthetic oil broke down so easily Mac trucks would go under quick. These guys have to put in so much oil it doesn't make sense(epsecially because of how much $ it takes to change the oil) to change it often. They test it every so many thousand miles and wait to see when an oil may be close to breaking down and then change it.
Now questions have been ask about RP, RL, and other big names whether they provide better protection (on engine oils only) and the answer has been NO. However, these brands have shown you can go longer on an OIC (oil interval change) than other brands like Val, Castrol, Mobil, etc. So if you do spend the money on these motor oils, go longer between changes or you're just wasting your money.
Hell, these guys have even gone to tell you how to recognize where an oil was made, if it has the right packaged detergents, etc., etc., by just looking at the bottle.
They have also gone and test Wal-Marts synthetic brand and some have shown the same qualities as M1, coming from the same distributors, but at half the price. However the general consensus is still to change the Wal-Mart brand every 3,000-5,000.....name can have such a prominent affect on ppl.
apexbeast
May 11, 2014 12:38 AM
leo_99
Feb 25, 2013 08:20 AM
Debug
May 9, 2011 10:14 PM
kdogg
Jan 5, 2006 10:52 AM
evo2fast
Aug 7, 2004 09:57 AM
