Problems after cam install
Old Mar 22, 2006 | 06:46 PM
Gonzo0991's Avatar
Unhappy Problems after cam install
Hey guys,
I just had a local shop install my cams (264/272) and cam gears (Vishnu adj. set at -2,-2). The car was running great before I got these parts installed; however after the install the car is only hitting 12psi of boost. I called the guy who installed them, to ask him if any piping was removed (thinking it might just be that it wasn’t put back on) but all the piping was untouched.
At idle my vacuum is around 15-18psi. and at full throttle I’m peaking at 12psi.
My modifications are:
Helix turboback exhaust
Apex'i Intake
10.5 hotside
Xede (v.3)
264/272 HKS cams
Vishnu Cam gears (-2,-2)
Old Mar 22, 2006 | 06:52 PM
EVOLVEU's Avatar
check hoses that connect to the turbo nip and wastegate/ actuator. sounds like you are running on wastegate boost ie 12psi.
Old Mar 22, 2006 | 06:54 PM
nhsean69's Avatar
Yeah what he said, my hoses were messed by the dealer and i had the same issue, so if the dealer can screw it up, i dont doubt a shop would
Old Mar 22, 2006 | 06:56 PM
Blue Evo 8's Avatar
boost leak?
bad wastegate?
boost controller?
is the timing done right?
Old Mar 22, 2006 | 07:02 PM
GinuwineEvo8's Avatar
Boost controller isnt hooked up correctly ...
Old Mar 22, 2006 | 07:07 PM
Gonzo0991's Avatar
I just checked that nipple, and the hose is on there securely.
Old Mar 22, 2006 | 07:10 PM
Gonzo0991's Avatar
My friend who gave me a ride to the shop drove behind me on the way back home, and he said that it smelled really bad. I told him I was running catless, and he said it smelled worse than ever. I think im goin to put on the stock airbox and see if that helps at all.
Old Mar 22, 2006 | 11:55 PM
Danny23's Avatar
boost controller or bov, sounds like that to me. after i did the cams on my 03 8 with a new uncrushed 1G bov i couldnt get above 16 psi. after i crushed it 21 psi to redline. what bov do you have?
Old Mar 23, 2006 | 12:05 AM
dzl's Avatar
dzl
You have a boost leak.
Old Mar 23, 2006 | 06:04 AM
3volution8's Avatar
doesnt boost leak seem improbable (althogh im not saying it couldnt be) because the Xede which he is running controls the boost, unless the map he uploaded after the cam install messed with the boost control settings on his Xede. Xede=ebc
Old Mar 23, 2006 | 06:05 AM
8urv8's Avatar
I put in a new controller a few weeks ago and I noticed the other day the it was turned up all the way and I was only getting about 17 psi. I put in the stiffer spring and all was well. What do you mean by the bov being uncrushed?
Old Mar 23, 2006 | 06:19 AM
TTP Engineering's Avatar
Camgears may be out of phase. The vishnu gears are strangely set to a white paint mark and not the timing mark for some reason. They likely got it wrong.
Old Mar 23, 2006 | 06:25 AM
trinydex's Avatar
it smells worse because you're running hugely rich... fix yer boost problem.
ruzs
47
Feb 6, 2008 10:37 PM
evo 8 ya
19
Aug 18, 2004 07:07 PM
The Emperor
12
Jun 29, 2004 07:42 PM
Boost Solutions
Mar 12, 2004 04:38 PM
Bonefish
Jan 13, 2004 05:03 PM
