5th gear grind and Dealer scare tactics
Old Apr 25, 2006 | 04:41 PM
mazdryk's Avatar
I have a 2003 evo 8 with 27k miles on it. I have a slight grind when i shift into 5th gear. This is covered under warranty right? I also KNow there is a TSB for this problem. I have changed my clutch to a very harsh 6 puck unsprung clutch good for 650 lbs of tourque. Can this be the cause of my grind or void my warranty? The dealer says that if its my fault then i need to pay 1.8k to fix the tranny. What should I do? What should I say to the service manager? I think he wants to blame me for it.
Old Apr 25, 2006 | 04:45 PM
EEvo's Avatar
its a syncro i think as i have the same problem and people tell me my syncro is bad.
Old Apr 25, 2006 | 04:46 PM
yooyooyoo's Avatar
i had a similar problem in reverse, apparently 5th and reverse share the same syncro if you have a 5 speed. I have a IX.
They fixed it with no complaints. Of course this was HB Mitsu and I have no mods.
Old Apr 27, 2006 | 07:57 PM
mazdryk's Avatar
bump
Old Apr 27, 2006 | 08:19 PM
TEXSRT4's Avatar
they might try to blame it on the clutch...even though its not really connected
but im suprised you asked. after all, with teh evo the added weight of you sitting in teh car and driving it is enough to void your tranny warranty. you see the added stress of the extra weight put unneccesary strain on the tranny which caused it to fail. its your fault and your stuck
Old Apr 27, 2006 | 08:21 PM
Turbo Meg's Avatar
Sounds about right
Old Apr 27, 2006 | 08:46 PM
MuslimEvoFreak's Avatar
Good luck man trying to get your evo fixed. They will notice that you have an aftermarket clutch and they probably won't cover the synchros under warranty.
Old Apr 27, 2006 | 08:52 PM
4WS Tuning's Avatar
its probably not ur fault for the gear grinding...but the clutch does put a little more stress on the tranny....and even at lenient dealerships they will tell you that aftermarket parts directly related to things that fail will not be covered....so maybe u should pick up a used stock clutch, get that thrown in for 400-500$ then while they are fixing the tranny ask the dealer to put the aftermarket clutch back in....i've read quite a few people doing that...
good luck!
Old Apr 28, 2006 | 05:03 AM
adamhw's Avatar
If they won't cover it, you can try changing the fluids. Don't pay the dealer for repair, if you need it fixed send to shep or tre, they are cheaper, and will upgrade tranny.
Old Apr 28, 2006 | 05:07 AM
ibanez_926's Avatar
Your screwed, unless your dealership is really cool. I went thru 6 months of bs with them for my 5th gear on my 2003 and i had the stock clutch. Eventually i just said **** it, and took the transmission out myself and sent it to TRE.
Old Apr 28, 2006 | 06:05 AM
dayf's Avatar
You can always do a sheptrans rebuild for 880. For now, are you double clutching at least to save the gear? That works for quite a while.
Old Apr 28, 2006 | 06:48 AM
gsujeff55's Avatar
find a better dealership. point blank
Old Apr 28, 2006 | 09:10 AM
truedefekt's Avatar
my 03 tranny is getting rebuilt under warranty, otherwise i would pull it out and send to tre .. except I have a horrible grinding noise when letting off the gas in any gear tsb covers it and I wont have to pay anything for mits problems
Old Apr 28, 2006 | 10:08 AM
South Side Evo's Avatar
Not honoring warranty requests (not just modified Evo's) is the big problem with Mitsubishi. This is a well known cost saving tactic from them, and did cost them a considerable amount of lost sales. With this being said, your chances are slim if you modified your car. As a general rule of thumb, if you modified your car, and you have problems, you should remove the mods before taking it to the dealer, or just pay for the fix from a non-dealership (so your VIN doesn't go on file as a altered vehicle).
SleepySamurai13
15
Apr 29, 2009 12:53 AM
Bl@ckburn
Dec 3, 2007 04:37 PM
figuerda
20
Sep 28, 2005 07:33 PM
chase2000gt
Jun 21, 2005 12:05 PM
feldguy
Apr 9, 2004 08:29 PM
