evo9 boost 15psi??
evo9 boost 15psi??
i just installed an autometer boost gauge, it only boost at 14-15 psi, no matter how hard i try!! help guyz.............. i got a hks bov with pip
I got a Autometer z-series boost/vacum gauge and had the same problem..so I tested it against some other boost gauges and was 3-4 psi lower than the others...so I just took it back and got another 1 and is now within .5 psi to the others.
Now it reads between 18-19 psi full boost.
Again look at what you just said. You put an aftermarket BOV on and prolly didnt recirc it. When you do this the evo loses boost because the BOV "leaks" it out. The way our cars are setup its not a good idea to put a aftermarket BOV on. The stock 1g BOV is the best one. If you are going to buy any BOV it shoudl be that one.
I suggest putting the stock one back on and then see what happens
sphynx
15
Jul 25, 2011 09:27 PM
RNSpeed
Nov 14, 2009 12:09 PM
crasher
Jan 11, 2007 08:57 AM
