Soooo... V1 hardwire was a piece of cake...
Old Jun 18, 2006 | 04:40 PM
MRCole's Avatar
I am a clean freak. Any after market wiring i run, i make look factory. My alarm, my avn7000, all the wiring is clean and neat.
But since it is fused, it's not quite so bad. And yes, to each their own!
Old Jun 19, 2006 | 11:53 AM
XK120's Avatar
did you disconnect the battery before doing this?
Old Jun 19, 2006 | 12:05 PM
Schuyler's Avatar
Naw - I figured since it was a switched outlet (the 15a fuse I used), it wouldn't be energized without the key in the "on" position.
Old Jun 19, 2006 | 01:13 PM
XK120's Avatar
thanks! one more question...is the safe? the guy above mentioned a fire hazard...just dont want to take any chances with my brand new IX!
Old Jun 19, 2006 | 04:53 PM
Schuyler's Avatar
I can't tell you if it's 100% safe - but I ran the same set-up for 4 years on an Acura and had zero problems. If you use the V1 hardwire kit, it is a fused red wire. If you use the fuse, the worst thing that can happen is you need a new fuse, for the most part, IMHO.
StreakGSX
May 1, 2025 02:24 AM
dcdirtrider
16
May 15, 2016 01:42 PM
BadKarmaCreepin
Evo X How Tos / Installations
Apr 7, 2015 06:35 PM
Summit1
Apr 28, 2011 12:23 PM
XstormtrooperX
Jan 27, 2011 12:13 PM
