First oil change
Old Jul 8, 2006 | 06:21 PM
akgvr4riceater's Avatar
i think his car will be ok
Old Jul 8, 2006 | 08:59 PM
EvoRSvIII's Avatar
Registered User
I just don't understand why anyone would refute the owner's manual that was created by the manufacturer of the car based on recommendations from the engineers who have designed and tested the vehicle over and over to gover 9 generations strong. Do you think they are keeping a huge secret from us and in reality we are supposed to rag on our cars fresh out of the box to make them bullet proof?
Old Jul 9, 2006 | 03:45 AM
South Side Evo's Avatar
Here's an interesting link on engine break-in
http://www.mototuneusa.com/break_in_secrets.htm
Old Jul 9, 2006 | 04:51 AM
sinajoon5's Avatar
so... mobil 1 synthetic 10w30???
Old Jul 9, 2006 | 06:00 AM
TonyMS's Avatar
It is so funny how people can read something on the internet or a message board and take it as gospel truth. The bottom line is Mitsu made the car they have tested the car and they have the most gain from giving the correct info on how to use and take care of the car. I would be willing to bet the section on how to use the radio in my owners manual has more thought and time put into it then most of what you will read here on else where or the internet.
I did the manual breakin and changed the oil at 1k and will change it at 3k intervals w/ mobile 1
Old Jul 11, 2006 | 02:11 PM
biga27110's Avatar
you done ****ed up
Old Jul 11, 2006 | 02:13 PM
9xfaster's Avatar
I did my first oil change at 1,000 miles.
Old Jul 11, 2006 | 08:02 PM
barneyb's Avatar
Originally Posted by JimmyZ
Ordinarily this might be a dumb question but considering the way you broke your car in I am going to ask it. You do know that you WILL ruin your engine if you put just regular motor oil in right?
The main reason for using synthetic oil in your Evo is to help prevent plugging the turbo oil feed line with coked oil. This can happen if the engine is shut down with the turbo very hot. If the turbo oil line becomes plugged you then lose the turbo. Synthetic oil is less susceptible to oxidation at high temperatures.
I'm from the DSM crowd and most turbo 4G63 DSM's were driven with conventional oil in the crankcase with only the occasional problem. I personally drove my DSM over 100,000 miles using mostly conventional oil. Some winters I switched to synthetic oil to help with starting problems. The starters on DSM's were kind of feeble.
So, while this is enough of a reason for the maker to recommend the use of synthetic oil, it doesn't mean you will automatically ruin your engine with a fill of conventional oil.
Old Jul 12, 2006 | 01:46 AM
evo8kiko05's Avatar
i feel sorry for your EVO!!!! You should have took really care in Breaking that thing in. Think about it, it's like baking a cake. You dont wanna put any load on that Brand new motor and keep from Cooking the "Brand new gaskets and Seals. " Breaking in your motor correctly will Definitely increase the life of it in the long run. I can see, you running in to probs when before your first Timming belt change....
Old Jul 12, 2006 | 01:56 AM
adrenaline1's Avatar
Originally Posted by hondafan
i've always heard that hard break in leads to excessive oil consumption in the evo. i did 600 miles of easy driving, maybe 1 psi boost, no higher than 4K rpm, and i never have to add oil between 3K mile oil changes.
only 03s experienced oil related probs from hard brake in
ur cars fine dude.. but definately use synthetic unless u plan to leave it stock and not drive it hard which doesnt look to be the case
Old Jul 12, 2006 | 05:19 AM
Steve_P's Avatar
This has been endlessly debated and people's opinion differ. First, you should probably always listen to the mfgrs recommendations- that makes sense. Saying that, do you really think that when you buy a car with even 5 miles on it that it hasn't seen over 5000 RPM? What do you think they do at the factory when they test run the engine and car? They dog it, and they should to see if there are any problems.
In addition, here's a datapoint (real info, not "you just ruined your engine" coming from a 23 yr old psychic internet mechanic that's never even rebuilt a lawnmower engine). I bought a new AWD DSM in 11/91, drove it hard right off the lot, regularly to 7000 RPM with no easy "break-in" changed the oil every 3500-4000 miles with at best 50/50 synthetic/conventional. The engine has 267,000 miles on it, never been rebuilt, and uses a qt of oil every 1000 miles. So, I'd say you didn't ruin your seals, gaskets, rings, etc and will be fine.
Also, why do people religiously say "listen to the engineers" with reference to break in (I can't argue with that) but then change their oil at 1000 miles- which is not listening? Save your money and go at least 3000 miles between changes unless you're truly road racing the car- on a track, not a few seconds of WOT here and there in daily driving.
Old Jul 12, 2006 | 08:32 AM
05 MR's Avatar
As several individuals have pointed out, people have different opinions about break in. I put weeks of research into this topic and ended up deciding to use MotoMan's method. http://www.mototuneusa.com/break_in_secrets.htm
I did my first oil change at 26 miles. This was after trailering the car (new with 4 miles on the odo) to my local Mustang Dyno to break in the engine. Engine oil was changed to regular petroleum for the first 200 miles as Synthetic limits proper break in (works too well). The oil change at 26 miles revealed oil that was absolutely full of tiny metal shavings (just as MotoMan said). Since using this method, my Evo has been perfect. I use essentially no oil between changes. The rings have have sealed perfectly. Compared to other “stock” Evo’s, my vehicle seems to have a decided advantage at the racetrack in the power department. MotoMan’s advice comes highly recommended.
Old Jul 12, 2006 | 11:16 AM
lowbdgtmechanic's Avatar
Originally Posted by pashasevo
the reason i asked is because i read that mitsu uses special additive in their oil and i read that it is bad to change the oil too soon...but since i broke it in so damn hard i figured its necessary to change it sooner....right?
kinda funny, when you assume that. You read the manual or whatever and forgot to find out "what if i drive it hard?"...oh well, i did my first oil change...2,500.
Old Jul 12, 2006 | 11:24 AM
JaReDbOy's Avatar
Just thought I would contribute my personal experience with the '03 i bought brand new.
I followed the normal break in.. didnt get on it for the first.. 1200 or 1500 miles ( i forget)
and I didnt change my oil until 5,000.
It went through this weird phase where it burned oil alot- (about 1 qt every 2000 miles).. from about maybe 10,000 -15,000 ( if i remember correctly).
then after that the car was fine. never burned much oil in between changes after that.
So far im waiting for 5000 to change the oil in my 9 ( got 3200) but I really havent gotten on the car too hard. ok.. maybe a few times...
WW13X
Jan 5, 2017 03:33 PM
sriracha303
12
Sep 25, 2015 09:48 PM
RrK
Lancer Troubleshooting
10
Aug 2, 2010 09:16 AM
GgreyEVOIX
Nov 20, 2006 04:31 PM
__NiTe__
Jul 6, 2004 04:06 PM
