Stock Evo 9 + tune = power gain????
Old Aug 11, 2006 | 01:05 PM
  #31
sesso's Avatar
i got a flash and didnt get good results. i had soooo much knock i had to cut the timing in half almost. in my opinion ur better off getting a TBE then doing a tune but a custom tune... every car is different so i think mail in flashes are a waste to me.
Old Aug 11, 2006 | 01:20 PM
  #32
DruMMinStUd06's Avatar
i should look into this
Old Aug 11, 2006 | 01:26 PM
  #33
Rnm's Avatar
Rnm
I would attribute that to be your own fault. If I recall, you had a mail in flash with a drop in filter and you were boosting 22-24psi all while on stock exhaust and on pump 91 octane. Sounds like a recipe for disaster if you ask me!
Old Aug 11, 2006 | 01:44 PM
  #34
JDMevoBOOST's Avatar
hmmmm if thats the case then im gonna have to have my friend figure out how to make it quieter
Old Aug 11, 2006 | 01:45 PM
  #35
sesso's Avatar
dude I had nitro in my tank mixed with it. I never boost above 22psi on pump alone. and yes with the mail in there was 30 knock counts at one point at 21 psi.
if ur recalling a dropin only... that was the first 2 weeks I had the car. 6k later I do my own maps boost to 28psi and have 0 knock counts. there is others that say the same thing about mailin but I'm not saying names noteven the map I paid for cuz he is a good dude. I just think mailins don't work well.
Old Aug 11, 2006 | 01:53 PM
  #36
ApexVIII's Avatar
No, Apex, you get the MOST gains on a IX with a tune. It doesn't matter if you're stock or modded...tons of power to be gained from a tune.
A $199 mail-in flash will make more power than an $800 TBE.
i know that a tune will get you more then tbe, but i was saying that you will get alot more with TBE, and a tune sorry i didn't word it verry well
Old Aug 11, 2006 | 01:55 PM
  #37
RalliArtEvoVIII's Avatar
TT>Dynoflash any..damn..day. Avoid the horror stories, head to Mark at turbotrix
Old Aug 11, 2006 | 01:56 PM
  #38
by saying horror stories, i mean the customer service.
Old Aug 11, 2006 | 02:21 PM
  #39
daisaw1219's Avatar
I actually got a flash from dynoflash and I didn't feel that much of a diffrence compared to stock. I only felt a diffrence after a mbc set to 20psi.
Old Aug 11, 2006 | 02:29 PM
  #40
sesso's Avatar
exactly. at 4000 rpm I had -1 timing advance. which it terrible. my map may have been for 93. but even with some other ummm stuff it still knocked. I had pull pull 2* off the mail in timing
Old Aug 11, 2006 | 02:58 PM
  #41
gonzstarr's Avatar
I got my car EcuTek flashed over at TopSpeed, baseline was 261hp and 256tq...after flash the car made 300hp and 307tq... it made a huge diference... the car is completely stock, the only thing we did was remove the restrictor from one the boost lines... but, it definately needs a turbo back, once you get used to that power you always want more...and you want it to sound the part too...
Old Aug 11, 2006 | 03:11 PM
  #42
sesso's Avatar
I bet its dyno tuned that's way diff then even tho now ur locked out of ur ecu except if they do it for u but if u don't use ecuflash I guess it wouldn't matter
Old Aug 11, 2006 | 07:12 PM
  #43
FartMuffler's Avatar
Originally Posted by jasonc32amg
That's the pot calling the kettle black, go play with your ser...
er... i did start the thread.... and the evo will be my next car in a month or so... so go play with yourself
Old Aug 11, 2006 | 07:23 PM
  #44
Methodical4u's Avatar
So if you add mods to it after you have it flashed... don't you need to have it reflashed again?
Old Aug 11, 2006 | 07:33 PM
  #45
Jussb1aze's Avatar
check out vishnu's xflash for the ix, according to the website it gives you hp gains stock, and should be able to hit low 12's with it.
