30,000m tune up?
Old Aug 21, 2006 | 09:29 AM
aboh6leenz's Avatar
30,000m tune up?
Just hit 30k miles and was wondering what mitsu says to do. I can't find my owners manual right now. If anyone could just tell me what I need to do that'd be great.
Thanks,
Austin
Old Aug 21, 2006 | 09:32 AM
gsrboi80's Avatar
All drivetrain fludis, Serp belt.
Old Aug 21, 2006 | 09:48 AM
zeus1's Avatar
i think plugs too
Old Aug 21, 2006 | 11:47 AM
barneyb's Avatar
Check fuel tank
Check fuel hoses
Change air filter
Check drive belt
Check exhaust system
Change engine oil & filter
Change transaxle oil
Change transfer oil
Change coolant
Check coolant hoses
Check brake hoses
Check ball joint and steering linkage seals
Check suspension
Check axle boots
Change rear differential oil
Check brake pads and rotate tires
Old Sep 5, 2006 | 12:50 PM
MooneyDriver's Avatar
Zeus. Are the tires still available and if yes please describe their condition?
Old Sep 5, 2006 | 01:30 PM
MidEvo's Avatar
Originally Posted by barneyb
Check fuel tank
Check fuel hoses
Change air filter
Check drive belt
Change transfer oil
Change coolant
Check coolant hoses
Check brake hoses
Check suspension
Check axle boots
eek, how much does that cost at the stealership?
Old Sep 5, 2006 | 01:33 PM
IrightI's Avatar
about $500.
Old Sep 5, 2006 | 01:34 PM
evo/X's Avatar
do you not have a warranty?
Old Sep 5, 2006 | 01:42 PM
jqturbo's Avatar
Originally Posted by IrightI
about $500.
What? Just to change your oil, transaxle oil, transfer oil, and coolant?? Cause everything else is just "checking" which dealerships probably won't even do anyways! Then again they'll say they do and try to charge you for something else.
Old Sep 5, 2006 | 01:45 PM
IrightI's Avatar
I have the little brochure right in front of me after taxes it will be over $500.. they charge you for the SUV 30k tune up because of the diffs.
WagsEvo's Avatar
I'm around 30K now too. I'm doing all the work myself, and it will be a lot cheaper than $500 for parts (fluids and plugs).
Old Sep 5, 2006 | 02:17 PM
IrightI's Avatar
^ +1 Im at 25,000 and I know for a fact it will be less then half of that (and I already changed my plugs)
Old Sep 9, 2006 | 05:42 PM
aboh6leenz's Avatar
holey crap $500 didnt know it'd be so much. I just changed my oil and am going to change plugs.
What fluids does everyone recomend?
Old Sep 10, 2006 | 07:13 AM
mathgeek's Avatar
Here's what I had done at the dealership when mine hit 30,000 miles:
Replace drive belt
Change transmission fluid
Change transfer case fluid
Change transaxle fluid
Total cost? About $530 or so. Total time it took? About 45 minutes once they had the car on the rack. Am I upset that it cost so much and looked to be relatively simple? Yeah, kind of. However, I'm not one to try something on my own unless I can watch and learn first. I'd love to do the maintenance myself, but I have neither the equipment nor the know-how to do it. So for now, I'll pay to have it done correctly. If anyone is willing to show me how to do it (in person), I'd never have the dealership do it again.
Also, the iridium spark plugs will last a long time - at least 60,000 miles. I wouldn't have the dealership replace those. They'll charge you about $21 per plug plus labor. Just buy some NGK's at Kragen and do it yourself.
Old Sep 10, 2006 | 07:27 AM
ashumo's Avatar
with google and evo forums...or even downloading the tech pub you could have handled it. all i needed was to see where the plugs were on the t-case and the fill on the tranny...found a decent right up at evomoto or something.
ohYouEvo
Apr 6, 2016 02:23 PM
Bear.914
Mar 10, 2009 09:13 PM
YNGEVO
Feb 6, 2009 12:52 PM
TurboWill
Jan 14, 2006 11:17 PM
MENTY
May 3, 2004 08:31 PM
