water leak right front kick panel anyone?
Old Oct 4, 2006 | 10:02 PM
2104's Avatar
i've only had my evo for 2weeks and i started noticing a water leak only on while driving on rainy days. i haven't located to source of the leak but would like to know if anyone else has a similar issue. "right front lower kick panel area".
Old Oct 4, 2006 | 10:07 PM
Dapper Dan's Avatar
i believe there was a recall on that because some people had it leak onto there ecus and mess them up, take it to the dealer...
Old Oct 4, 2006 | 10:26 PM
2104's Avatar
thanx, for the info. i was going to take it in. but i just wanted to ck around and see if anyone else had that problem. i don't want them to dick me around and say they didn't find any leaks. thanks again.
Old Oct 5, 2006 | 08:13 AM
idriveanevo's Avatar
Mine did the same untill i got a new windshield
Old Oct 5, 2006 | 08:24 AM
striderx88's Avatar
did u turn u r ac on??
Old Oct 5, 2006 | 08:00 PM
2104's Avatar
no, a/c was not on.
Old Oct 10, 2006 | 03:19 AM
Laxman's Avatar
My car is leaking like crazy right now. Only when it rains and the area directly under the passenger seat becomes a swimming pool. Even with a towel, I found a half inch of water under the seat alone. And that wasn't even with the car moving, just from rain alone. Any suggestions on what is causing this? Also, anyone know of a good dealer in NM/TX?
Old Oct 10, 2006 | 08:58 AM
Ph3n1x's Avatar
Happened to me and the whole drivers side all the way to the driver rear passenger was soaked under the carpet. Took it to Mitsubishi to figure it out. Apparently some gromet was loose and water kept comming in. They fixed it under warranty and its been good since.
Old Oct 11, 2006 | 04:41 PM
Psquared's Avatar
If I would have seen this thread I wouldn't have started mine....anyhow, I had the passenger side turn into a lake also after driving to work in the rain...the dealer thinks it's the a/c unit that's clogged....i'm still working this one though....
Old Oct 11, 2006 | 09:06 PM
Laxman's Avatar
I got mine fixed today! ...hopefully. Basically the grommet for the gauge cluster in the firewall was not making a seal. Somewhere along the line like the stealership I bought from, never put that on right and my car had become a swimming pool ever since.
ggevo23
Jan 11, 2013 08:30 PM
gerry cap
Jan 17, 2011 06:41 PM
cpunlamd
Oct 25, 2010 07:58 PM
vroomevo
Jul 26, 2008 10:25 PM
Fujilicious
10
Dec 3, 2007 12:27 PM
