Need help removing front axle...
Old Oct 5, 2006 | 06:26 PM
Dapper Dan's Avatar
i used a prybar....just keep prying and rotating it....it can be pretty stubborn but it will come off....
Old Oct 6, 2006 | 09:36 AM
sonicnofadz's Avatar
Originally Posted by dekfu1
The cotter pin and castle nut have been off since the start of things. Thats not the problem, it seems as if the axle has seized in the hub.
It's hammer time!
Old Oct 6, 2006 | 10:07 AM
era-teknic.com's Avatar
pop the back of the axle out of the tranny just a little bit, then spray some lube, wait a few minutes, then a few good taps with hammer. might also want to loosen the 4 hub bolts so it has more play. hope that helps.
Old Oct 6, 2006 | 12:31 PM
althemean's Avatar
you dont have to remove the tie rods. You can simply undo the front strut and it will allow the brake rotor/hub ***'y to drop down and the axle should slide right out. Getting it out of the hub should be the easiest part.
Old Oct 13, 2006 | 08:25 PM
ak47po's Avatar
Old Oct 13, 2006 | 11:19 PM
joeymia's Avatar
Originally Posted by ak47po
good job posting the wrong info.
Old Oct 14, 2006 | 11:08 AM
althemean's Avatar
there are different ways to approach the same problem. I removed the strut and the hub came off the axle w/o having to undo all the tie-rods. These were taken 5 minutes ago as I am in the middle of my rebuild.
Passenger side..note the two holes for the strut and the zip tiees holding the hub up so it does lay completly flat.
Note how the tie rods are still intact and the suspension removed.
Attached Thumbnails Need help removing front axle...-axle-removal-001.jpg   Need help removing front axle...-axle-removal-002.jpg   Need help removing front axle...-axle-removal-003.jpg
Old Oct 14, 2006 | 01:58 PM
kf6ytc's Avatar
i think he's having issues removing the axle from the hub not the shaft............. simply back the king nut out a tad and wack it with a hammer!
Old Oct 14, 2006 | 11:22 PM
CO_VR4's Avatar
Usually a dead blow hammer will be sufficient if you give yourself enough room to physically allow the hub to slide off of the axle. Sometimes they will feel like they've seized into the hub, but patience and liberal applications of PB Blaster or the like will usually solve the problem.
I routinely coat the axle and inside of the hub splines with antiseize when reassembling.
Jonno99
May 5, 2017 02:05 PM
evowizzler
Feb 26, 2009 06:58 PM
diameters
04-06 Lancer Ralliart How To Requests / Questions / Tips
58
Aug 28, 2007 09:10 PM
mxjs
Jun 30, 2006 09:52 AM
Knyght
Mar 26, 2005 06:40 PM
