Most Accurate Boost Gauge on the Market.
Old Mar 8, 2007 | 03:32 PM
  #151
vboy425's Avatar
Defi link series and BF. The Defi D-gauge is a piece of **** and so is the new blue one which is the discontinue d-gauge series and now defi change the light bulb to blue.
The Defi BF gauge dead on match my Zeitronix reading.
Old Mar 8, 2007 | 04:30 PM
  #152
_EVOlved_'s Avatar
Good info...
Old Mar 9, 2007 | 05:45 PM
  #153
tlcoll1's Avatar
For the people who say "my gauge is off" - how do you know? If you're comparing it to a MAP sensor read-out, how do you know the MAP sensor is accurate? MAP sensors have a number of issues, and will give different read-outs at different elevations. Additionally, the MAP sensor read-out will vary with the weather ("there's a high presssure front coming in..."), and they also vary in accuracy based on temperature and pressure. Here's another data point - some people were complaining about the boost number from my ECU+ product when using the GM 3-bar MAP sensor, so I the tested a customer's new-ish sensor and a brand new one. Results: brand new one was about 1 PSI low, and varied by about 1/2 PSI across a few trials. The almost-new one was 3 PSI low, and varied by as much as 5 PSI from trial to trial, especially around 20 PSI. (The ECU+ software was, of course, spot on, but it can't do anything to correct a screwed up MAP sensor.)
Tom
Old Mar 9, 2007 | 06:10 PM
  #154
_EVOlved_'s Avatar
So then what is the correct and accurate device then?
Old Mar 9, 2007 | 06:22 PM
  #155
TTP Engineering's Avatar
Zeitronix calibrates for altitude.
If barometrics affect your map sensor with weather the same barometrics are affecting the air the car ingests so it makes no difference. It is working exactly as it should.
Old Mar 9, 2007 | 07:03 PM
  #156
_EVOlved_'s Avatar
I like Zeitronix but its tooo expensive...
Old Mar 9, 2007 | 08:16 PM
  #157
DJ_StEpH's Avatar
zeitronix ftw! but it is fkin expensive..
Old Mar 9, 2007 | 09:16 PM
  #158
ddubdb3's Avatar
definatly stewart warner they look good very cheap compared to defi and accurate i have the 0-40 psi
Old Mar 9, 2007 | 11:17 PM
  #159
_EVOlved_'s Avatar
SW isnt bad
Old Mar 10, 2007 | 07:18 PM
  #160
Q8_EVO's Avatar
ZT2.. Prices never go down on that piece.
Old Mar 10, 2007 | 07:22 PM
  #161
kmcconn9's Avatar
My SW is dead on...although I have been thinking about getting the AEM Digital Boost which would match my wideband perfect
Old Mar 10, 2007 | 08:34 PM
  #162
We have great deals on ZT2's.
Old Mar 10, 2007 | 08:48 PM
  #163
_EVOlved_'s Avatar
Rich EVO MR SE
May 10, 2007 07:46 PM
AKgambler47
Apr 10, 2007 02:43 AM
E VOL IX
May 2, 2006 04:32 PM
an0ther
Sep 16, 2005 08:19 AM
EvoRs
May 6, 2004 06:04 AM
