danger to overfilled transmission and t-case?
Yes this is the area of least resistance and fluid will typically seep out from there first.
Should I worry about draining it or just let it come out on its own. Also specs say the Tcase needs .58 quarts and I was wondering how much is that actually should I be good with half a quart?
Ok so just to clarify I should be good then right, theres no need for me to drain it again and refill it cause its seeping out of the driveshaft. A buddy of mine told me its the seal that goes in between the Tcase and the driveshaft but it didnt start doing it until I put more fluid in it today. I was driving the vehicle for a week and decided to put more fluid in the Tcase cause the vehicle was making a loud whinnin noise and my buddy told me it could be cause of low fluid.
as eddie at roadrace explained it to me there's just about no way you're gonna rupture a seal in the tranny, even if you fill up yer tranny at an angle to overfill it. what will happen is it'll ooze out of the axle on the driver side as that's what happened to me. but it's not biggie.
it'll also ooze for quite some time as a tiny bit of overfill translates into many days of drip drip on your parking floor
I will get under the car and just release the fill bolt to see if any excess comes out. I was at a slight positive angle when filling and used pretty damn close to 2.9qts. Just not sure if this is supposed to happen or if I blew a seal.
Any insight, comments, suggestions?
Super old bump but can anyone confirm this? I changed my driveline fluids yesterday only to find an accumulation of trans oil on the undertray
Both the transmission and the transfer case have vents. The vents release air, not gear oil, as the gear boxes heat up in use.
The maker put the fill holes at a particular level for a reason, up to the fill hole is full. The only possible exception to this is perhaps the transfer case where the oil being added needs to seep through roller bearings. So add until it comes back out of the fill hole, let sit, then add more if possible.
Because of the vents there is no pressure in either the transmission or the transfer case. If there is oil leaking from a seal it is a bad seal.
The capacity of the transfer case is 0.6 quarts. How you accidentally get 2.9 quarts in there is beyond me. However, supposing the entire volume of the transfer case is 2.9 quarts and there is no air inside, oil expands with heat too, and in this case that is what will be coming out of the vent.
This entire thread needs to go in the trash, It is filled with misinformation.
Haha, trans as in transmission. Per the service book, receives 2.9 quarts. That'd be a lot in the transfercase! Thank you again for the response though!
EvilDSM97
Jul 16, 2016 06:10 PM
RSGuy
30
Nov 10, 2015 05:37 AM
polish_pounder
24
Oct 13, 2014 01:04 PM
VT Mitsu
Jan 6, 2007 12:57 PM
car, case, excursion, ford, happen, overfill, overfilled, overfilling, rupture, s2000, seals, transfer, transmission, underfill, vs
